Full Version: MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
Show messages:  1-18  19-38  39-58  59-78  79-93
29 Jan 2024   [#59] In reply to [#58]
works like a charm!
Rest to make something for use any profil against only the rectangle for the moment!
29 Jan 2024   [#60] In reply to [#59]
Hi Pilou.
A small rectangle to the side is one of the profiles that is used to form the pipe. I made him visible. Depending on the selected curve, it will be located in different places. This is a method that moves the "pipe profile" away from the "guides" to avoid conflicts. The mechanism of pipe construction consists of creating solid bodies using profiles and guides, and then the body that is inside is subtracted from the one in which it is located.
30 Jan 2024   [#61] In reply to [#60]
So not easy to put any other reasonable profil(s) ?
30 Jan 2024   [#62] In reply to [#60]
Hi WN,
thanks for spotting the issue not come across that before.
I have attached a nod file to produce various sections along a path based on the Pipe Tool.
Can you test it please.
Barry
Sections.nod
30 Jan 2024   [#63] In reply to [#62]
Cool...
I replace Knobs by Cursors ! ;)
Cursors must be added to Height, Width, Wall
Rotation must be something like -360 to + 360
Waiting the free section ;)
Speedy test with the Free Vizcom! :)
30 Jan 2024   [#64] In reply to [#63]
<<I replace Knobs by Cursors ! ;)
Not sure what you mean ?
360 +or - makes no difference it's a complete revolution.
You can add 3 sliders (Height , Width , Thickness) feeding a Concat node and plugin to Section.
Barry
30 Jan 2024   [#65] In reply to [#62]
Thanks Barry, wonderful macro. I just added a little, maybe it will be useful to someone.
https://disk.yandex.ru/d/sGB4eKL-q8URbQ
Sections_mod.nod
30 Jan 2024   [#66] In reply to [#64]
<<Not sure what you mean ?
Just that Cursors/Sliders are more easy to move with a mouse than Knobs...
<< 360 +or - makes no difference it's a complete revolution.
yes but when you have for example first go to 150°
with negative values you can go to -220° if wanted! (else it was blocked to 0°)
It's with that i have made my spaceship! :)
30 Jan 2024   [#67] In reply to [#66]
thanks now I understand.
Barry
30 Jan 2024   [#68] In reply to [#66]
The 'knob' and 'slider' widgets are well controlled by the middle mouse button, even when minimized.
30 Jan 2024   [#69] In reply to [#67]
And about -360 to + 360 Permits Clock wise and anti-Clock wise!
30 Jan 2024   [#70] In reply to [#68]
@WN
About Knob + Wheel : cool trick but less speedy than simple cursor (slider) when you must go -1000 to + 1000 ;
30 Jan 2024   [#71]
Hi WN,
thank you for your suggestions.
The problem is there are so many standard sections & the concat node is limited to 6 inputs.
I have made a manual input nod file as Pilou suggested for now please have a look.
I have also modified the positioning of the profile in the 'Y' axis as just moving in the 'X' did not clear the bounding box
when a path is just a straight line on the 'Y' if that makes sense.
This applies to the Pipe tool as well so will update my post.
have made the rotation +- 180 and now a manual input for profile sizes.
Many thanks to you both.
Barry
Manual Sections010224.nod
30 Jan 2024   [#72] In reply to [#71]
Cool new version
For the next :)
General concept of the sweep with one rail!
But take only case of the profil is touching the rail else that will be headache of the Profil orientation!!!
31 Jan 2024   [#73]
WOW! from a small request so much function, so many tools to play with and so many possible directions. Off to play....
many thanks to all who have input keeping MOI the sharpest pen in the pack.
All the best Alex.
2 Feb 2024   [#74]
have updated the pipe tool with a minor bug fix.
Also have modified the Sections nod file.
Have removed the gate selection system and replaced with a slider.
A fillet adjustment slider as also been added.
Barry
19 Feb 2024   [#75]
Hi All just getting some test files ready to put through the 4 axis pipe bender - and for some reason I cant shell this rebuilt curve from a series of arcs I have checked continuity and all seems to be OK. Any ideas would be helpful.
TORIDIAL KNOT 1m TUBE TEST.3dm
19 Feb 2024   [#76] In reply to [#75]
Hi Alex, I simplified the rail by using the v5 merge command on it so that it's all one segment instead of in multiple segments and if you sweep this version and select the end faces it looks like it's shelling ok then.
TORIDIAL KNOT 1m TUBE TEST_2.3dm
19 Feb 2024   [#77]
Thanks Michael for speedy reply with the merge command it looks like the ARC info is lost - I need to retain this so the tube bender has the curve continuity to calculate the bends for each sequence along the part hope that makes sense.
19 Feb 2024   [#78] In reply to [#77]
Hi Alex,
try boolean inner from outer rather than shell.
Barry
Pipe Boolean.3dm
