Full Version: MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
Show messages:  1-15  16-35  36-55  56-75  76-93
25 Jan 2024   [#36] In reply to [#20]
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
25 Jan 2024   [#37] In reply to [#36]
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
26 Jan 2024   [#38]
Hi Barry,
Many thanks for posting your NODE Pack - all working great really powerful node - what is the process of selecting multiple control paths to form the group of multiple selection?
Alex.
26 Jan 2024   [#39] In reply to [#38]
Hi Alex,
I just select all paths then index through them with the knob selecting pipe or box with the switch and applying.
When trying to do the Boolean operation on all of them at same time caused problems.
Barry
Update;
you can try bypassing the index select and plugin directly into the RevSwitch.
Just tried with 100 curves and it took 20 sec for pipe and 30 sec for box.
Any problems you can revert to index select.
27 Jan 2024   [#40] In reply to [#37]
Hi Barry,
I believe I did (if I did not mess anything up!) However, it still doesn't work! you can see my path (Dashed curve) It has a name "Path" and I did not select it before opening Nodeeditor.
27 Jan 2024   [#41] In reply to [#40]
Hi Drillbit,
From your photo the switch is set to multi paths so you will get nothing as you have selected get by name.
Make sure your pipe size is not to big for your path.
If your still having trouble post your path and I will have a look.
Barry
28 Jan 2024   [#42] In reply to [#41]
Hi Barry,
Everything works fine now :-)
Tanx!
28 Jan 2024   [#43]
Hello
I have 2 curves selected (multi select node) ...works fine but seems i can't keep both of them in the same time?
What i miss ?
i used this Barry node http://moi3d.com/forum/index.php?webtag=MOI&msg=11314.30
28 Jan 2024   [#44]
Another thing :)
At the end of a node session I must use this script for select objects generated existing on the screen!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
is that the same for you ?
I have maybe not the last version of nodeeditor!
Nodeeditor 1.1 jms
Message 11314.45 was deleted
28 Jan 2024   [#46] In reply to [#45]
so only the multi select to Swicht or other thing ?
Because i have only one object result but 2 curves selected..
29 Jan 2024   [#47] In reply to [#46]
The multi select indexes thro your selections one at a time so you need to apply your selection before moving to the next selection.
This allows you to choose between pipe or box.
If your selections are all the same (pipe or box) give them the same name and select by get by name.
Hope that’s clear.
Barry
29 Jan 2024   [#48] In reply to [#47]
Very "sportive" nodes! :)
here select the 2 rectangles in the same time !
29 Jan 2024   [#49] In reply to [#48]
The small rectangle looks to small for the pipe size you have used thus the problem.
Can you post your shapes and settings so I can check.
Cheers.
Barry
29 Jan 2024   [#50] In reply to [#49]
here the file!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/for_barry.3dm
But it not really a problem because it's a solid! :) auto-intersected! :)
29 Jan 2024   [#51] In reply to [#50]
the nod file will not calculate multi different shapes at one time.( it will if all shapes are the same)
I have modified the nod file to take multiple paths but you will need to index thro them one at a time choosing
Pipe or Box fillets or no fillet etc.
The nod file includes the use of MO (M0_TE) new fillet curve & note nodes so I have included my latest Nodeditor.
Also included is my test file.
Please let me know of any issues.
Barry
Edit 30/01/24
Correction thanks to WN the node will now do multiply paths at same time.
Have updated nod file.
Another bug fix so latest version Pipe Tool 300134
Bug fix 02/02/24 version Pipe Tool 010224
nodeeditor.zip
Pipe Test.3dm
Pipe Tool 010224.nod
29 Jan 2024   [#52] In reply to [#51]
OK i will test that!
I replace the knob by a cursor with no decimal number
For me a knob is not practical...
29 Jan 2024   [#53] In reply to [#51]
Cool that you have linked your nodeeditor
Works fine for alone path except the fact that i don't find how sweep a profil along a path!
29 Jan 2024   [#54] In reply to [#53]
I do not understand can you give an example.
Barry
29 Jan 2024   [#55] In reply to [#54]
Something like that :)
with your example of path given
