Full Version: MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
Show messages:  1-20  21-40  41-60  61-80  81-93
23 Jan 2024   [#21] In reply to [#20]
Yes, I edited my previous post! Please take a look.
23 Jan 2024   [#22] In reply to [#20]
Hi Drillbit,
it's as I thought its the display node.(In between Fillet to compare)
Just wire straight to the compare node and delete the display node.
Barry
23 Jan 2024   [#23] In reply to [#22]
Hi Barry-H,
Now the run button is active but it does nothing! I open the nodeeditor and then select the curvepath and update Mulit Select
The Curve path turns into dashed line then I hit apply it disappears! And by closing the nodeeditor the selected curve path appears again.
Needless to say I tweak other nodes but nothing happens. and Even MOI Crashed!
- Psygorn
23 Jan 2024   [#24] In reply to [#23]
Hi Drillbit,
so after running you get nothing ?
Open nodeditor before selecting any objects for some reason if you select and then open nodeditor it locks up.
It maybe that get by name is a better option but that's one path at a time.
Will investigate and let you know.
Barry
23 Jan 2024   [#25] In reply to [#23]
@Psygorn - the crash could probably be mitigated by converting booleans to use processing in moi_commandprocessor.exe instead of in-process.
Like MO describes for fillets here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.348
23 Jan 2024   [#26] In reply to [#25]
Thank you Michael,
as always!
- Psygorn
23 Jan 2024   [#27] In reply to [#26]
Hi Drillbit,
multi select causes problems so change select method to select by name its more stable.
Make sure when opening Nodeditor no paths are selected for some reason this causes a lockup.
If there are close Nodeditor deselect and open Nodeditor again.
Barry
23 Jan 2024   [#28]
Such settings cause a long and tedious wait.
24 Jan 2024   [#29] In reply to [#28]
Hi WN,
the issue with the settings you used is the fillet needs to be larger than half box width.
I will add a mini fillet restriction to avoid this.
Barry
24 Jan 2024   [#30]
Replaced file see https://moi3d.com/forum/index.php?webtag=MOI&msg=11314.51
24 Jan 2024   [#31] In reply to [#29]
Hi Barry.
Thanks!
24 Jan 2024   [#32] In reply to [#30]
Hi Barry,
I think now Rev Switch node doesn't work! (what is it or where should I find it?)
- Psygorn
24 Jan 2024   [#33] In reply to [#32]
Hi Psygorn.
It can be thrown out and switched manually, it will work the same way.
24 Jan 2024   [#34] In reply to [#32]
Hi Drillbit,
a link to where the Switchrevers is in my previous post.
It allows the ability to switch path curve to pipe or box.
I think this way only the required part is calculated.
Anyway give it a try.
Barry
24 Jan 2024   [#35] In reply to [#8]
Barry-H,
Thank you for posting the updated nodeeditor zip.
I have been missing the Updated Display node for many months, due to having an old r2d3.js file in the node > extensions folder, (with nodes showing up in nodeeditor canvas under infos.)
The "newer" r2d3.js file shows a date of 3/9/23, and has 736 code lines.
This r2d3js file creates a new menu entry in nodeeditor canvas, (r2d3), with 9 node entries (currently).
25 Jan 2024   [#36] In reply to [#20]
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
25 Jan 2024   [#37] In reply to [#36]
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
26 Jan 2024   [#38]
Hi Barry,
Many thanks for posting your NODE Pack - all working great really powerful node - what is the process of selecting multiple control paths to form the group of multiple selection?
Alex.
26 Jan 2024   [#39] In reply to [#38]
Hi Alex,
I just select all paths then index through them with the knob selecting pipe or box with the switch and applying.
When trying to do the Boolean operation on all of them at same time caused problems.
Barry
Update;
you can try bypassing the index select and plugin directly into the RevSwitch.
Just tried with 100 curves and it took 20 sec for pipe and 30 sec for box.
Any problems you can revert to index select.
27 Jan 2024   [#40] In reply to [#37]
Hi Barry,
I believe I did (if I did not mess anything up!) However, it still doesn't work! you can see my path (Dashed curve) It has a name "Path" and I did not select it before opening Nodeeditor.
