18-37
38-57
58-77
78-93
Hi Drillbit,
are you using the nodeditor I have posted ?
Post a screenshot of the open macro this would help.
Barry
Method added see gif below.
Hi Barry-H,
No, I am using my own tuned nodeeditor. If I can find out what is missing in my nodeeditor I can add that and I guess things will be fine!
And, thanks for the attached image, but I believe I did the very same thing yet no results! (the run button is not active!)
Here is the insde of the Macro
-Psygorn
Hi Drillbit,
have you opened the macro yet ?
Barry
Yes, I edited my previous post! Please take a look.
Hi Drillbit,
it's as I thought its the display node.(In between Fillet to compare)
Just wire straight to the compare node and delete the display node.
Barry
Hi Barry-H,
Now the run button is active but it does nothing! I open the nodeeditor and then select the curvepath and update Mulit Select
The Curve path turns into dashed line then I hit apply it disappears! And by closing the nodeeditor the selected curve path appears again.
Needless to say I tweak other nodes but nothing happens. and Even MOI Crashed!
- Psygorn
Hi Drillbit,
so after running you get nothing ?
Open nodeditor before selecting any objects for some reason if you select and then open nodeditor it locks up.
It maybe that get by name is a better option but that's one path at a time.
Will investigate and let you know.
Barry
@Psygorn - the crash could probably be mitigated by converting booleans to use processing in moi_commandprocessor.exe instead of in-process.
Like MO describes for fillets here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.348
Thank you Michael,
as always!
- Psygorn
Hi Drillbit,
multi select causes problems so change select method to select by name its more stable.
Make sure when opening Nodeditor no paths are selected for some reason this causes a lockup.
If there are close Nodeditor deselect and open Nodeditor again.
Barry
Such settings cause a long and tedious wait.
Hi WN,
the issue with the settings you used is the fillet needs to be larger than half box width.
I will add a mini fillet restriction to avoid this.
Barry
Replaced file see
https://moi3d.com/forum/index.php?webtag=MOI&msg=11314.51
Hi Barry.
Thanks!
Hi Barry,
I think now Rev Switch node doesn't work! (what is it or where should I find it?)
- Psygorn
Hi Psygorn.
It can be thrown out and switched manually, it will work the same way.
Hi Drillbit,
a link to where the Switchrevers is in my previous post.
It allows the ability to switch path curve to pipe or box.
I think this way only the required part is calculated.
Anyway give it a try.
Barry
.png)
Barry-H,
Thank you for posting the updated nodeeditor zip.
I have been missing the Updated Display node for many months, due to having an old r2d3.js file in the node > extensions folder, (with nodes showing up in nodeeditor canvas under infos.)
The "newer" r2d3.js file shows a date of 3/9/23, and has 736 code lines.
This r2d3js file creates a new menu entry in nodeeditor canvas, (r2d3), with 9 node entries (currently).
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
18-37
38-57
58-77
78-93
