Full Version: V5 Bug
Show messages: All  1-4  5-13
28 Nov 2023   [#5]
If you drag to select then move it does crash but if you just click and move the tall object it does not crash.
There are a lot of extra geometry that are not part of the solid that may be causing the issue:
28 Nov 2023   [#6] In reply to [#5]
Hi Charlie, do you get a crash dump file created?
30 Nov 2023   [#7] In reply to [#3]
Ok, the crash is specific to new style Macs with the M1/M2 arm64 CPU. It's from a difference in behavior from Intel with how division by zero is handled. I'll have a fix for the next beta shortly.
Thanks, - Michael
30 Nov 2023   [#8] In reply to [#3]
New v5 beta at https://moi3d.com/beta.htm should fix this crash.
Thanks, - Michael
30 Nov 2023   [#9]
The Nov beta does fix the crash issue.
alteschinken: Your file has some weird anomalies in it. Not sure how you ended up with the geometry in the red circle, but you cannot select them.
30 Nov 2023   [#10] In reply to [#9]
There was a curve mirroring bug accidentally introduced in the Nov-29 v5 beta released yesterday.
So if you got that one please throw it out and get a new Nov-30 v5 beta instead at https://moi3d.com/beta.htm .
Thanks, - Michael
30 Nov 2023   [#11] In reply to [#10]
Wow! Michael, can you upload the new Nov-30 v5 beta to the Download section for OTOY subscribers?
30 Nov 2023   [#12] In reply to [#11]
Hi Moi3dFan,
Yes I'll send it to them.
1 Dec 2023   [#13]
There was another bug where objects that were hidden when initially loaded would get stuck in a wireframe display.
So there's another update and the current one is a Dec-1beta.
