Full Version: V5 Bug
Show messages: All
1-3
4-13
Hi alteschinken, what operating system are you running on?
Is there a crash dump file being generated?
I don't seem to be able to reproduce the crash over here.
If you drag to select then move it does crash but if you just click and move the tall object it does not crash.
There are a lot of extra geometry that are not part of the solid that may be causing the issue:
Hi Charlie, do you get a crash dump file created?
Ok, the crash is specific to new style Macs with the M1/M2 arm64 CPU. It's from a difference in behavior from Intel with how division by zero is handled. I'll have a fix for the next beta shortly.
Thanks, - Michael
New v5 beta at
https://moi3d.com/beta.htm should fix this crash.
Thanks, - Michael
The Nov beta does fix the crash issue.
alteschinken: Your file has some weird anomalies in it. Not sure how you ended up with the geometry in the red circle, but you cannot select them.
There was a curve mirroring bug accidentally introduced in the Nov-29 v5 beta released yesterday.
So if you got that one please throw it out and get a new Nov-30 v5 beta instead at
https://moi3d.com/beta.htm .
Thanks, - Michael
Wow! Michael, can you upload the new Nov-30 v5 beta to the Download section for OTOY subscribers?
Hi Moi3dFan,
Yes I'll send it to them.
There was another bug where objects that were hidden when initially loaded would get stuck in a wireframe display.
So there's another update and the current one is a Dec-1beta.
Show messages: All
1-3
4-13
