Full Version: V5 Bug
20 Nov 2023   [#1]
When trying to slice a tube, using a pane, the slice is about 45 degrees different from the angle of the slicing pane. I have included the MOI file for an example. This may be a bug.
Fish Hook Remover.3dm
20 Nov 2023   [#2] In reply to [#1]
Hi alteschinken, there are 2 objects at the cutting location, one is a rectangle curve (this one):
And the other is a plane surface:
You'll get different results if you select the either the curve or the surface as the cutting object, because planar curves will make a cut by extruding out a cutting volume like this:
If you select the plane as the cutting object and not the curve it should work as you wanted.
Please let me know if you're still seeing a problem there.
28 Nov 2023   [#3]
Attached is a file which opens fine. However, when I select the tallest object, and try to MOVE it, it will crash every time.
28 Nov 2023   [#4] In reply to [#3]
Hi alteschinken, what operating system are you running on?
Is there a crash dump file being generated?
I don't seem to be able to reproduce the crash over here.
28 Nov 2023   [#5]
If you drag to select then move it does crash but if you just click and move the tall object it does not crash.
There are a lot of extra geometry that are not part of the solid that may be causing the issue:
28 Nov 2023   [#6] In reply to [#5]
Hi Charlie, do you get a crash dump file created?
30 Nov 2023   [#7] In reply to [#3]
Ok, the crash is specific to new style Macs with the M1/M2 arm64 CPU. It's from a difference in behavior from Intel with how division by zero is handled. I'll have a fix for the next beta shortly.
Thanks, - Michael
30 Nov 2023   [#8] In reply to [#3]
New v5 beta at https://moi3d.com/beta.htm should fix this crash.
Thanks, - Michael
30 Nov 2023   [#9]
The Nov beta does fix the crash issue.
alteschinken: Your file has some weird anomalies in it. Not sure how you ended up with the geometry in the red circle, but you cannot select them.
30 Nov 2023   [#10] In reply to [#9]
There was a curve mirroring bug accidentally introduced in the Nov-29 v5 beta released yesterday.
So if you got that one please throw it out and get a new Nov-30 v5 beta instead at https://moi3d.com/beta.htm .
Thanks, - Michael
30 Nov 2023   [#11] In reply to [#10]
Wow! Michael, can you upload the new Nov-30 v5 beta to the Download section for OTOY subscribers?
30 Nov 2023   [#12] In reply to [#11]
Hi Moi3dFan,
Yes I'll send it to them.
1 Dec 2023   [#13]
There was another bug where objects that were hidden when initially loaded would get stuck in a wireframe display.
So there's another update and the current one is a Dec-1beta.
