9-28
29
Hi Matadem,
You can get the real-time distortion now by turning on History updating on the result of Flow. Be sure to do this immediately after doing Flow since even a tiny edit on any of the objects involved in Flow, like moving a point, will prevent history from working.
Select the objects resulting from Flow and then do Edit > History > "Enable update".
When you move edit points of the target point you should see distortion updating in real time.
History updating is turned on by default for some commands, but not for Flow. That's why you have to turn it on manually.
- Peer
9-28
29
