6-25
26-29
Hi Matadem,
How is Distort different from using Flow like Michael suggested?
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10114.453
If you want more than 4 control points you can do that by first drawing a grid of lines and then select the lines and do Construct > Network to make a plane. If you select the resulting plane and do Edit > "Show pts" you'll see the control points that you can then drag.
Is the problem that the result doesn't update in real time while you're dragging points?
- Peer
I hope @Zarkow will take a challenge and make his Benz using only MOI and new rebuild surface!
Tanx for the links Pilou :-)
Yep something like a realtime warp/distort would be nice.
Hi Matadem,
You can get the real-time distortion now by turning on History updating on the result of Flow. Be sure to do this immediately after doing Flow since even a tiny edit on any of the objects involved in Flow, like moving a point, will prevent history from working.
Select the objects resulting from Flow and then do Edit > History > "Enable update".
When you move edit points of the target point you should see distortion updating in real time.
History updating is turned on by default for some commands, but not for Flow. That's why you have to turn it on manually.
- Peer
6-25
26-29
