151-170
171-190
191-210
211-223
Using v5 beta Dec-1-2023
If I have a object group hierarchy as follows:
Group01
Components
Dimensions
Etc
When I select one of the group's elements, say one of the Components, and change its size via the object's properties, the entire group is scaled along with the object I edited. I was expecting that if I select only one of the group's elements, I could edit it and change only that element. I went back through the beta release notes & did not notice anything about this, so am asking, is this expected behavior? While it is kind of neat, it is also unexpected & seemingly inconsistent with the notion that things outside of the selected object are being changed.
--Larry
Hi Larry,
Thanks for reporting this - it looks like a holdover from some previous behavior where if you have an edge of a cylinder selected you could modify it there and it would scale the whole cylinder.
But I agree that for a group sub selection it is not expected for the entire parent group to be affected. I will adjust that.
Thanks, - Michael
Michael,
When I click the web link, it says "Current version: Dec-1-2023." Typo?
Edit:
Sorry, see another user posted the same comment earlier.
Hi Michael!
Could you tell us a scheduled date for the official V5?
Hi Marco, I'm sorry there is not a set date yet. It is taking time to work through various bugs.
Ok, thanks for the info. But just to get a slightly clearer idea… are we talking about a release by summer, fall, or by the end of the year? Thanks.
Hi Marco,
Sorry I don't know the answer to this currently.
Hallo Michael,
da meine version V4 schon lange abgelaufen ist, gibt es da eine Möglichkeit die V5 zu testen?
Viele Grüße Pit
Normally if you have the V4 license key no problem for download the V5 beta! ;)
http://moi3d.com/beta.htm
'Ich habe keinen License Key, ich hatte eine Testversion v4. I
So I am affraid you can't test yet the v5 beta!
wann ist mit der V5 zurechnen?
Michael indicated that V5 will be released when it is ready...
So no fixed date given yet.
151-170
171-190
191-210
211-223
