Full Version: V5 beta Apr-13-2023 available now
Show messages:  1-3  …  144-163  164-183  184-203  204-223
24 Feb 2024   [#204] In reply to [#203]
Hi Fubax, I've seen the undo multiplication, I think it's not related to groups.
It's on my radar to get fixed too though.
Thanks, - Michael
17 Mar 2024   [#205]
I would like to report another bug, now with the pinning of "Unnamed" objects.
• When nothing is selected and you Ctrl+Left click on the "Unnamed" right side in the objects list, there's no pin icon, but nothing can be selected afterwards, both in the objects list, as well as in the viewport. Only hiding and un-hiding the "Unnamed" object fixes things back to normal.
• When "Unnamed" object is selected, and you perform Ctrl+Left click on the yellow icon in the objects list, pin icon also does not occur, but now the "Unnamed" object cannot be deselected. Again only hiding and un-hiding fixes things back to normal.
18 Mar 2024   [#206] In reply to [#205]
Hi Fubax, thanks for reporting the bug with setting a selection filter (Ctrl+click) on the "Unnamed" entry. I can repeat it over here and I will investigate a fix.
5 Apr 2024   [#207]
Hi Michael,i have questions,when you release v5?Or new beta iteration?Did you have any date for announcement? Thanks
5 Apr 2024   [#208] In reply to [#207]
Hi blackboard,
I'm waiting on bug fixes for the ACIS library before releasing the v5 final version. Sorry I don't have a set date yet for when that will be done.
Probably have another beta release pretty soon though but I also don't have a set date for that either, sorry.
14 May 2024   [#209]
Whenever I wanted to download latest version, it only shows: Current version: Dec-1-2023.
The file is also MoI v5 beta Dec-1-2023.zip...
Michael
14 May 2024   [#210]
Last Beta version is the Dec. 1st 2023.
The thread where you post is Apr-13 but it's 2023.
Have fun
13 Jun 2024   [#211]
Using v5 beta Dec-1-2023
If I have a object group hierarchy as follows:
    Group01
        Components
        Dimensions
        Etc
When I select one of the group's elements, say one of the Components, and change its size via the object's properties, the entire group is scaled along with the object I edited. I was expecting that if I select only one of the group's elements, I could edit it and change only that element. I went back through the beta release notes & did not notice anything about this, so am asking, is this expected behavior? While it is kind of neat, it is also unexpected & seemingly inconsistent with the notion that things outside of the selected object are being changed.
--Larry
13 Jun 2024   [#212] In reply to [#211]
Hi Larry,
Thanks for reporting this - it looks like a holdover from some previous behavior where if you have an edge of a cylinder selected you could modify it there and it would scale the whole cylinder.
But I agree that for a group sub selection it is not expected for the entire parent group to be affected. I will adjust that.
Thanks, - Michael
13 Jun 2024   [#213] In reply to [#1]
Michael,
When I click the web link, it says "Current version: Dec-1-2023." Typo?
Edit:
Sorry, see another user posted the same comment earlier.
14 Jun 2024   [#214]
Hi Michael!
Could you tell us a scheduled date for the official V5?
14 Jun 2024   [#215] In reply to [#214]
Hi Marco, I'm sorry there is not a set date yet. It is taking time to work through various bugs.
18 Jun 2024   [#216] In reply to [#215]
Ok, thanks for the info. But just to get a slightly clearer idea… are we talking about a release by summer, fall, or by the end of the year? Thanks.
18 Jun 2024   [#217] In reply to [#216]
Hi Marco,
Sorry I don't know the answer to this currently.
13 Jul 2024   [#218] In reply to [#217]
Hallo Michael,
da meine version V4 schon lange abgelaufen ist, gibt es da eine Möglichkeit die V5 zu testen?
Viele Grüße Pit
13 Jul 2024   [#219] In reply to [#218]
Normally if you have the V4 license key no problem for download the V5 beta! ;)
http://moi3d.com/beta.htm
17 Jul 2024   [#220] In reply to [#219]
'Ich habe keinen License Key, ich hatte eine Testversion v4. I
17 Jul 2024   [#221] In reply to [#220]
So I am affraid you can't test yet the v5 beta!
30 Jul 2024   [#222] In reply to [#221]
wann ist mit der V5 zurechnen?
30 Jul 2024   [#223]
Michael indicated that V5 will be released when it is ready...
So no fixed date given yet.
