138-157
158-177
178-197
198-217
218-223
Hi Brian, thanks for reporting this crash. I think I've got a fix, I've sent you a test build.
> So I guess my question is, where is the documentation of how to create and do a construction line.
The construction line docs are here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#constructionlines
> Where is the latest construction line script. (mine looks like 2009 version?)
I think there are links here:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
Hallo Michael,
steht schon ein Termin für die Moi v5 an.
LG
Pit
Hi Pit, sorry there isn't a final v5 release date set as of yet.
I'm still in the process of working on the ACIS integration.
Hello,
I would like to report a bug.
When you copy an object from within a group, paste it (do not move), select come face, and delete it, the whole group gets duplicated upon deleting the face. Only disabling history for the duplicated object, or moving it prevents this bug from occurring.
I love new beveling capabilities.
See ya
Hi Fubax, thanks for reporting this bug. I can reproduce it over here, I will investigate it. It looks like the pasted object still thinks it is part of the original group.
Thanks, - Michael
Hi Michael, there's also similar thing happening sometimes when I Ctrl+z deleted objects, they get multiplied each time I undo. Maybe that's related, but I don't know any specific conditions to recreate that, it seems to happen in more complicated projects. ¯\(°_° )/¯
Hi Fubax, I've seen the undo multiplication, I think it's not related to groups.
It's on my radar to get fixed too though.
Thanks, - Michael
I would like to report another bug, now with the pinning of "Unnamed" objects.
• When nothing is selected and you Ctrl+Left click on the "Unnamed" right side in the objects list, there's no pin icon, but nothing can be selected afterwards, both in the objects list, as well as in the viewport. Only hiding and un-hiding the "Unnamed" object fixes things back to normal.
• When "Unnamed" object is selected, and you perform Ctrl+Left click on the yellow icon in the objects list, pin icon also does not occur, but now the "Unnamed" object cannot be deselected. Again only hiding and un-hiding fixes things back to normal.
Hi Fubax, thanks for reporting the bug with setting a selection filter (Ctrl+click) on the "Unnamed" entry. I can repeat it over here and I will investigate a fix.
Hi Michael,i have questions,when you release v5?Or new beta iteration?Did you have any date for announcement? Thanks
Hi blackboard,
I'm waiting on bug fixes for the ACIS library before releasing the v5 final version. Sorry I don't have a set date yet for when that will be done.
Probably have another beta release pretty soon though but I also don't have a set date for that either, sorry.
Whenever I wanted to download latest version, it only shows: Current version: Dec-1-2023.
The file is also MoI v5 beta Dec-1-2023.zip...
Michael
Last Beta version is the Dec. 1st 2023.
The thread where you post is Apr-13 but it's 2023.
Have fun
Using v5 beta Dec-1-2023
If I have a object group hierarchy as follows:
Group01
Components
Dimensions
Etc
When I select one of the group's elements, say one of the Components, and change its size via the object's properties, the entire group is scaled along with the object I edited. I was expecting that if I select only one of the group's elements, I could edit it and change only that element. I went back through the beta release notes & did not notice anything about this, so am asking, is this expected behavior? While it is kind of neat, it is also unexpected & seemingly inconsistent with the notion that things outside of the selected object are being changed.
--Larry
Hi Larry,
Thanks for reporting this - it looks like a holdover from some previous behavior where if you have an edge of a cylinder selected you could modify it there and it would scale the whole cylinder.
But I agree that for a group sub selection it is not expected for the entire parent group to be affected. I will adjust that.
Thanks, - Michael
Michael,
When I click the web link, it says "Current version: Dec-1-2023." Typo?
Edit:
Sorry, see another user posted the same comment earlier.
Hi Michael!
Could you tell us a scheduled date for the official V5?
Hi Marco, I'm sorry there is not a set date yet. It is taking time to work through various bugs.
Ok, thanks for the info. But just to get a slightly clearer idea… are we talking about a release by summer, fall, or by the end of the year? Thanks.
Hi Marco,
Sorry I don't know the answer to this currently.
138-157
158-177
178-197
198-217
218-223
