125-144
145-164
165-184
185-204
205-223
Hi,i think i found bug,if i fillet acis tube,he do wrong shanding
tube.stp
Hi blackboard, thanks for reporting this fillet bug, it seems to be a bug in ACIS in converting an n-sided fillet vertex blend specialized surface into a generic NURBS surface.
I'll need to send the bug in to ACIS, in the meantime I should be able to make an alternate type of conversion for these areas like in the attached version.
Thanks, - Michael
tube2.3dm
Open large MOI file via network shared drive hang in scanning mode. I work via a QNAP fileserver as I have various machines setup for design and machining. Recently upgraded to December release BETA and I now get this scanning hang issue - was never a problem before opening large files over the network. If I copy the file to local location file opens without scanning no problem.
any thoughts
Alex
Hi Alex, there hasn't been any changes in file loading for quite some time.
Did you recently change any of your network infrastructure?
I don't think there is much I can do about network access being slow, that's pretty much out of the app's control.
Hi Michael, I rolled back MOI to V4 and no problem in opening files across network. I have 2 other slave workstations 1 with win 10 other win 11 I never updated MOI on those running v4 and files open across network no problem. On the QNAP file server I havent done any firmware upgrades on that either for quite some time. For now Ill keep working in MOIv4 - maybe some security permissions as the program is beta? not sure
Hi Alex, can you please send me an e-mail at
moi@moi3d.com ? I'll prepare some test builds of earlier v5 versions if you are willing to test them out to hopefully pinpoint what caused the change in network behavior.
I only started using any of the V5 betas in the last few weeks. Running the Dec-1-2023 beta right now, I notice a considerable lag navigating the viewports and the UI in general. The exact same file will feel more sluggisch in V5 compared to V4. I don't know what changed to cause this (perhaps the grouping functionality?). Also, I can hear the fans of my Macbook Pro spin up when working, which it never did on V4.
Any thoughts?
Hi Fabien, can you please e-mail me (
moi@moi3d.com) your moi.ini file?
Also is it an Intel or ARM machine?
Thanks, - Michael
Same thing with Linux WineHQ, I can't use version 5 and I've tried everything, we've already exchanged messages but none of this has ever resolved anything.
FWIW, I've been running Moi3D on Ubuntu 20.04 under Wine since version 7 without incident. Currently running Moi3D V5 with Wine development version (9.1) which I've been doing for a few years as I found performance was better without any reliability problems. In the beginning I would thinker with moi.ini settings, but for quite some time have been running defaults as it just seems to work. The only very small nuisance is the "view controls window" which sometimes will stay in foreground of native Linux apps, but it is harmless. I would try restoring defaults in both Moi3D & Wine.
Sven
Crash occurs for my .3dm file, in MoI5beta, and in MoI4,
If there is one or more construction lines active,
and if an attempt is made to change General > Unit system: (from feet to meters, or vice versa)
Crash report was sent, and also emailed.
A simple rectangle in MoI4, plus a couple of construction lines, and NO dimensions added, also causes a crash.
I was using shortcut key Ctrl+Alt+C _ConstructionLine
(maybe that is the problem?)
So I guess my question is, where is the documentation of how to create and do a construction line.
Where is the latest construction line script. (mine looks like 2009 version?)
ConstructionLine3 link:
https://moi3d.com/forum/index.php?webtag=MOI&msg=1029.25
Hi Brian, thanks for reporting this crash. I think I've got a fix, I've sent you a test build.
The construction line docs are here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#constructionlines
I think there are links here:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
Hallo Michael,
steht schon ein Termin für die Moi v5 an.
LG
Pit
Hi Pit, sorry there isn't a final v5 release date set as of yet.
I'm still in the process of working on the ACIS integration.
Hello,
I would like to report a bug.
When you copy an object from within a group, paste it (do not move), select come face, and delete it, the whole group gets duplicated upon deleting the face. Only disabling history for the duplicated object, or moving it prevents this bug from occurring.
I love new beveling capabilities.
See ya
Hi Fubax, thanks for reporting this bug. I can reproduce it over here, I will investigate it. It looks like the pasted object still thinks it is part of the original group.
Thanks, - Michael
Hi Michael, there's also similar thing happening sometimes when I Ctrl+z deleted objects, they get multiplied each time I undo. Maybe that's related, but I don't know any specific conditions to recreate that, it seems to happen in more complicated projects. ¯\(°_° )/¯
Hi Fubax, I've seen the undo multiplication, I think it's not related to groups.
It's on my radar to get fixed too though.
Thanks, - Michael
125-144
145-164
165-184
185-204
205-223
