Full Version: V5 beta Apr-13-2023 available now
Show messages:  1-19  …  80-99  100-119  120-139  140-159  160-179  180-199  200-219  220-223
3 Aug 2023   [#140] In reply to [#138]
Since my Trial v4 version has expired for some time, the question is when can we expect a 5 full version and at what price.
I don't want to buy the 4 version first to try the updates because I only use Moi for my hobby and for fun (I'm retired).
Greetings from Hamburg
Pieter
4 Aug 2023   [#141] In reply to [#140]
Hi Pieter, I'm expecting the price for v5 will remain the same as v4. I'm not sure yet when v5 will be released, I hope sometime before the end of the year though.
9 Aug 2023   [#142]
Hi Michael
is it possible to select a point, a line or a surface when extruding ?
( it works with origin point )
9 Aug 2023   [#143] In reply to [#142]
Hi christian, currently there are not snaps available on the same object that is itself being manipulated. That's because of some problems that can happen with things kind of getting stuck on themselves.
I'd like to revisit that, but for now you can place a point object (Draw curve > More > Point) where you want to snap before doing the extrude.
9 Aug 2023   [#144] In reply to [#143]
Very clear Michael
Thanks for your quick response.
Christian
24 Aug 2023   [#145]
Not sure if this event has been reviewed:
Changing image properties with proportions sizes off, the image will revert back to original ratio when dragging the anchor size.
imgbox
24 Aug 2023   [#146] In reply to [#145]
Hi wayne,
Yes, dragging always uses the image's inherent aspect ratio. If you want to change the aspect ratio permanently you can edit the image in an image processing program to your desired new size.
24 Aug 2023   [#147] In reply to [#146]
Thank you!
Wayne
9 Sep 2023   [#148] In reply to [#141]
Hi, does this mean that if I buy version 4 now, I will also get the update to version 5 for free? Or is it not clear, and would it be better to wait and buy it when version 5 is released?
9 Sep 2023   [#149] In reply to [#148]
Hi cyanayc,
Possibly but I'm not certain. It depends on when the final v5 release is out which I don't have a specific target date for yet.
I would like to wrap up the v5 release by the end of this year but I can't promise that will happen.
13 Sep 2023   [#150]
Is there a way to add "live" checkmark on to Export mesh option (OBJ in my case).
I have some big models (STEP/IGES) and when tweaking export settings for export to OBJ MOI 3D takes very long time (takes about 2 minutes for this mesh) to display 6-7 million polys mesh in OpenGL (part by part slowly appears) and settings GUI is very sluggish/unresponsive when OBJ settings start to punch in.
I'd like the option to STOP live instant meshing until I edit all numbers (By now I know settings i usually want) without MOI starting to generate polygons as soon as the panel pops up.
So if there would be live/proceed or some sort of button on that panel which then start process instead starting as soon as it's opened ?
13 Sep 2023   [#151] In reply to [#150]
Hi Lewis,
Sorry, no MoI's UI is specifically designed to not need an update button like that, it just automatically cancels the current calculation and starts an updated one whenever any meshing parameters are modified.
One thing you could do is to select just one object and do File > Export, that will pop up the meshing options dialog on a low computation load and once you have the settings how you want cancel that export and the same settings will be used on your next full export.
- MIchael
14 Sep 2023   [#152] In reply to [#151]
Yeah, I've tried doing that too, but GUI feedback is still very, very slow, it takes like 15-20 seconds to TAB to another filed with this mesh :(.
So that's why i hoped i could "tune in settings on just one piece" and then "live" all other layers and hit export, but it always meshes firs tin GUI = 5 minutes wait for it to finish, and then it saves file (Exported OBJ was 12 GB ).
Thanks anyway.
14 Sep 2023   [#153] In reply to [#152]
Hi Lewis, what are your machine specs?
You mean exporting just one single object is taking that long?
If this particular model is made up only of one individual extremely complex object then draw in a sphere or a box and select it and use File > Export on that to alter settings.
Yes you can do that, select the just one piece and use File > Export, not File > "Save As".
Export will mesh only the selected objects while Save As does everything regardless of selection.
14 Sep 2023   [#154] In reply to [#153]
My machine is Win10 64bit, AMD Threadripper PRO 3955WX, 256GB RAM, 2*RTX 4090 + RTX 3090, NVMe 1GB drive.
As for GUI slownnes, when GUI export popup window show up and then i try do drag slider it's sluggish, even typing the value is so slow that here is 15-20 sec pause between going to next input field.
I know it's because of big model but yeah that's why i hoped there could be "delayed" update button or so for those cases.
When model is not so big it's fine, GUI is responsive in those situations..
chers
14 Sep 2023   [#155] In reply to [#154]
Hi Lewis, what happens if you go into moi.ini (Options > General > "Edit .ini file" button) and change:
[Mesh Export]
ThreadLimit=8
Is the GUI on a heavy export less hiccupy then?
If yes then that probably indicates that I can do some (tricky) work to improve the GUI response when a whole lot of calculation threads are being used.
17 Sep 2023   [#156] In reply to [#155]
Hmm i tried that and yes maybe GUI is a bit more responsive (nothing major) now but now overall exporting process is slower now since it uses only 30-31% of my CPU strenght/cores (my CPU is 16c/32t).
It wasn't hitting 100% before either but it was 50-70% so faster export overall :).
thanks for idea.
17 Sep 2023   [#157] In reply to [#156]
Hi Lewis, thanks for testing that. Does your model happen to have some large individual surfaces in it?
I think the GUI stutters are probably when it's blocking waiting for the current in progress meshing to finish being canceled. I think I should be able to improve this, I will try.
21 Sep 2023   [#158] In reply to [#157]
Graphics driver?
25 Sep 2023   [#159]
Thanks Michael,
every optimization/speed-up is always welcome :).
