Full Version: V5 beta Apr-13-2023 available now
Show messages:  1-8  …  49-68  69-88  89-108  109-128  129-148  149-168  169-188  …  209-223
15 May 2023   [#109] In reply to [#108]
Hi Martin,
> It seems the correct bounding box dimensions are available in the Edit Size box, but MoI is not using them
> in this instance. The linked video shows the problem quite well.
Thanks for reporting this bug, I can repeat it over here and have put it on my list to investigate.
For now to complete your drawing you can use the BoundingBox command followed by Transform > Mirror to get the precise mirrored result.
15 May 2023   [#110] In reply to [#109]
Thanks for checking this out and thanks for the BoundingBox tip. ;-)
Martin.
15 May 2023   [#111]
Hello Michael
The latest version has a feature that interferes a little with the process. This is Alt+Click when executing commands. In general, the problem is that when drawing, say, a circle, with Alt held down (to disable all bindings), a guide is now drawn. And it's incredibly infuriating I climbed everything, tried everything. but I can't turn it off.
15 May 2023   [#112] In reply to [#111]
Hi blackboard, thanks for reporting that Alt modifier key bug, I'm investigating it.
18 May 2023   [#113]
Hey,Michael, can you say pls when will the next beta come out?
Already have an estimated release date?
18 May 2023   [#114] In reply to [#113]
Hi blackboard,
It will be as soon as I've fixed some bugs I'm working on. I don't know how long that will take, sorry.
Nope.
20 May 2023   [#115]
Greetings all.
I don't know if Im missing something, but does Revolve only work with positive angle numbers?
I want to do a 90 deg revolve of a circle to make a kind of elbow shape between 12 O'Clock and 3 O'Clock as shown in green in the attached video,
How do I get MoI to do that without resorting to use Rail Revolve, as -90 deg is ignored by the 'simple' Revolve tool?
Many thanks.
Martin.
https://vimeo.com/828662458?share=copy
20 May 2023   [#116] In reply to [#115]
Hi Martin, if you reverse the direction of the picked points that for the axis that will also reverse the direction of the revolve.
So like currently you're picking the start of the axis at the center point and then the 2nd point for it upwards along the z axis.
Instead pick the 2nd point downwards on the z axis to reverse it.
It would be a good idea if it did support a negative angle though, I have put that on my list to look at.
Message 11056.117 was deleted
20 May 2023   [#118] In reply to [#116]
Thanks Michael, reversing the rotation axis picks points does indeed do the job. If you do have time to include negative angles, then I would certainly appreciate that.
Thanks.
Martin.
22 May 2023   [#119]
Hi Michael.
I've been helping out a prospective purchaser of MoI and he seems to have found a bug when revolving a closed profile. I've included a short video of the problem. If the axis of rotation is set very slightly away from the profile, then it works as expected.
Martin.
https://vimeo.com/829230291?share=copy
22 May 2023   [#120] In reply to [#119]
Hi Martin,
Currently the profile to revolve can only have one coinicdent line of contact with the revolve axis.
A case like this with 2 lines in contact would need to generate a solid with a void region inside of it. Revolve doesn't know how to make that kind of result currently.
To get the desired result, you'll instead need to have 2 separate profile curves like this:
Then when those are revolved that will make 2 solids. Then boolean difference can be used with the inner solid as the cutting object to make a single solid with an internal cavity.
22 May 2023   [#121] In reply to [#120]
Thanks for the explanation, Michael.
Martin.
2 Jun 2023   [#122]
I've tried launching installer for this beta under WINE, but for some reason it fails - I get a blank, black window. For previous version it worked (but on the other hand I've updated the system since then.... at least I've tried running it in the same wine env).
edit: after some fiddling and switching to Wine 8 I was able to start the installer successfully. I've got the same problem with MoI4 installer, which previously worked correctly - so it's not MoI thing, but rather my configuration, WINE / Linux thing. On the positive note - after installing it seems to work beautifully , so I should be able to do some minor cad work when only my laptop is available.
25 Jun 2023   [#123]
Hello Michael,Do you already have a date for an approximate release of the update?
25 Jun 2023   [#124] In reply to [#123]
Hi blackboard,
Sorry no not yet.
29 Jun 2023   [#125]
I really want to create file new icons for commands in the interface, the most and naturally arising from this SVG icons.
The question arises, is it possible to use moi3d svg as icons
29 Jun 2023   [#126] In reply to [#125]
I believe that you must converter them in PNG images...
29 Jun 2023   [#127] In reply to [#125]
Hi blackboard, no the moi3d interface is not able to use .svg for icons directly, it is designed to use PNG images for icons.
You will need to convert your .svg into a 64x64 pixel PNG image and use the PNG.
3 Jul 2023   [#128] In reply to [#1]
Hello Michael!
How's it going? Hope everything's alright.
Have you some news about the V5 development?
Compared to V4 (that was a major rewrite at time) what are the advantages of this new upcoming V5?
And, last but not least, are there any current advantages to using the V5 beta compared to the official V4?
(I mean modelling speed, stability, better performance with Apple Silicon, etc...)
Thanks and have a good day.
