Full Version: V5 beta Apr-13-2023 available now
Show messages:  0-19  20-39  40-59  60-79  …  220-223
13 Apr 2023   [#1]
A new v5 beta (version Apr-13-2023) is now available for download here:
http://moi3d.com/beta.htm , also linked to from the download page on the main web site.
This has some more bug fixes for ACIS filleting.
13 Apr 2023   [#2]
Thanks for the new beta !
Here's an interesting result where Solid++ do a better job at filleting (constant dist - 0.5 cm - unit system : cm).
ACIS just 'break' the model.
Cheers.
13 Apr 2023   [#3]
Hello Michael,plasticity have great thing - loop select and ring select.Can you add it to moi in future?
13 Apr 2023   [#4] In reply to [#3]
Hi blackboard, there is a type of loop select that you can set up on a shortcut key, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3335.5
13 Apr 2023   [#5] In reply to [#3]
Oh also I've built a version of this beta for Otoy and sent it to them. So it should show up for Octane bundle subscribers soon.
13 Apr 2023   [#6] In reply to [#2]
Hi PaQ,
Thanks for posting it, I'm investigating it. I haven't figured out if it is a messed up fillet yet or a messed up translation from ACIS geometry.
13 Apr 2023   [#7]
Cool! No French translation to do! :)
13 Apr 2023   [#8] In reply to [#4]
yes i know,but moi as i saw have only loop select,plasticity have ring select too.Can moi have it?
13 Apr 2023   [#9] In reply to [#8]
Hi blackboard,
> Can moi have it?
Probably - do you have some example files and show the desired result with them?
14 Apr 2023   [#10] In reply to [#9]
here some examples what can do plasticity, if you add some of this things moi will be have more fast workflow,if core can do that why not add this to improve quality of life?
connected faces.mp4
edge loop.mp4
ring select.mp4
14 Apr 2023   [#11] In reply to [#10]
Select loop faces will be good too and select adjustment
If we start say about good thngs in plasticity which can be good look in moi
Here some features
1 clone from kitbash already on surface will be great too
2 Can moi have not only styles but full materials which can exported with file?
loop.mp4
materials.mp4
place.mp4
select adjacent.mp4
14 Apr 2023   [#12] In reply to [#11]
You have same as "placement" - Menu Orient
14 Apr 2023   [#13]
Ooph... got the BSOD upon fist using the ACIS fillet after installing.
Seems to have been something to do with Avast or Malwarebytes.
Works fine after rebooting.
Michael, I'm really enjoying the updated filleting options, especially the real-time result update.
14 Apr 2023   [#14]
In this new Beta (Apr-13-2023) we cannot Use ACIS to fillet Curves. (I am talking about 2D curves) I think in the previous Beta it was possible! though I am not sure!
-Psygorn
14 Apr 2023   [#15] In reply to [#14]
Hi Psygorn,
ACIS filleting has only been for edges, it hasn't been used for curve fillets in any of these betas.
14 Apr 2023   [#16] In reply to [#10]
Hi blackboard,
Please post some example .3dm files and the desired result so i can have a concrete example to test with.
14 Apr 2023   [#17] In reply to [#11]
Hi blackboard,
Sorry no that's not likely anytime soon.
14 Apr 2023   [#18] In reply to [#15]
Then I made a mistake. Sorry.
However, Do you have plans for it? (ACIS filleting for curves as well I think in some cases it could be useful maybe)
-Psygorn
14 Apr 2023   [#19] In reply to [#18]
Hi Psygorn,
Not really any plans for it currently, mostly because I don't know what there would be to gain from that. Do you have a case where you think it would be useful?
14 Apr 2023   [#20] In reply to [#19]
Yes, I have but when I think it through I realize that you are right. there would be no noticeable gain from that.
- Psygorn
