Full Version: Better quality with screen shots
10 Mar 2023   [#1]
If I use a monitor with 3840 x 2160 pixels instead of 1920/1080 is the quality of screenshots in this case better?
11 Mar 2023   [#2] In reply to [#1]
Hi Rudl, how are you doing the screenshots?
11 Mar 2023   [#3]
I make it with print on the keyboard
11 Mar 2023   [#4] In reply to [#3]
Hi Rudl, a better way to do the screenshot is by setting up a script on a shortcut key in MoI, as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.5
That generates an image basically to an internally allocated screen so it isn't limited by your actual monitor size.
11 Mar 2023   [#5]
Hi Michael, thank you very much.
I will try it tomorrow.
17 Mar 2023   [#6] In reply to [#5]
is it possible to enlarge the siz of the internally allocated screen. The picture has a size 0f 2560/2560 and I am not very happy with it.
17 Mar 2023   [#7] In reply to [#6]
Hi Rudl,
Yes, in the script code you can change the 2560, 2560 to something else. The upper limit will depend on what the video card driver supports.
17 Mar 2023   [#8]
Sometimes, I put certain variables in the front of the script, if I think I might need to change them.
My clipboard image script looks like...
script: /* CAPTURE RENDER */ var w = 3000; var h = 2000; var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 0; moi.grid.display = false; moi.view.meshAngle = 5.0; moi.grid.showXYAxes = false; moi.view.showHiddenLines = false; v.renderToClipboard(w, h); moi.view.lineWidth = 1; moi.grid.display = true; moi.view.meshAngle = 10.0; moi.grid.showXYAxes = true; moi.view.showHiddenLines = true; }
...and it's so easy for me to change the render size now. I just change w and h to whatever resolution I want.
18 Mar 2023   [#9] In reply to [#8]
Thank you. How can I find out, what my video card support.
18 Mar 2023   [#10] In reply to [#9]
Hi Rudl,
Well the main way is when you increase it and it doesn't work.
You may be able to find something like a maximum texture size on Windows using dxdiag.exe
18 Mar 2023   [#11] In reply to [#10]
I have a amd radeon rx 5700 xt
18 Mar 2023   [#12] In reply to [#11]
Hi Rudl, I'm not really sure where to find the maximum. You can just keep bumping it up by a couple of thousand and trying.
18 Mar 2023   [#13] In reply to [#12]
Thank you, I will try it.
