Full Version: Shortcut for line control points?
Show messages: All  1  2-7
15 Feb 2023   [#2] In reply to [#1]
Any free Shortcut in the first column & juste type Line in the second Column
or Press Tab and write Line (line LinE LIne etc... but without spaces )
15 Feb 2023   [#3] In reply to [#1]
Hi Matadem, do you mean you want to set up a keyboard shortcut that does the same thing as clicking the Edit > "Show pts" button in the side pane?
If so then go to Options > Shortcut keys to add in a new shortcut key and for the command part put in: ShowPoints
15 Feb 2023   [#4]
@Frenchy ...I did not quite understand :/
@Michael attached the needed one.
Thanks!
15 Feb 2023   [#5] In reply to [#4]
Hi Matadem, for that one put in Curve for the command part of the shortcut key.
15 Feb 2023   [#6]
Got it tnx!
15 Feb 2023   [#7]
Without image that was a little difficult to understand the question! :)
