Show messages: All
1-5
6-13
Hi Frank,
> (... I have no idea of what I'm wishing in term of time /developing budget).
Hard to say, maybe a year of work or something to design an API that would be so comprehensive to be able to get all the way down to modifying UV coordinates that are only being generated as part of the export process.
> At your knowledge today whats the best way to get decent unwraps on moi models?
I think many people throw out the auto generated ones from MoI and use whatever is in their main poly modeling program.
There's a function in Blender, something like "Average UV islands" that could probably process the MoI-generated UV coordinates too.
this is awesome! Thanx a lot for the share.
I was doing something similar for UV layout into UDIMs based on materials
Hello Paq,
Would you mind sharing one of these models (let's say, something of medium complexity), with and without your fix applied ? I'd be very curious to see what it takes to get to the same result in Blender, and would love to try it out.
Hi Prior,
Sure, sorry for the delay, I missed the notification.
In the meantime here's an updated version, using a lame brute force approach to reduce the stretching ... it seems to work better than the one made with my bad trigonometry / vector skills.
Does is works better than tagging / unwarp edge using existing MoI uv's boundaries ?
Short reply : NO
Long reply :
1) I'm facing a lot of Hou crash whit the Flatten method ... as I'm only manipulate existing data here, the 'tool' is quite robust.
2) 90% of the uv's coming from MoI are actually good, except they are stretched in u or v direction. They are also perfectly grid aligned : torus shape or tubes output a 'perfect' aligned rectangle, helping the packing process to maximize uv space.
Ultimately I could add a last check that will re-flatten the island that are still too distorted (easy), but I will only do it once I resolve the uv-flatten crash on some of those surfaces.
Hello, here's an updated version, using the last feature from Moi5 Beta to generate proper surface ID.
That's about the third time I rebuild this tool, the execution time is almost instant, and there is no more iteration to "find" the best value.
Create the layout / udim however can still take a few second / minutes depending of the number of surfaces (using native Hou UVLayout).
https://www.youtube.com/watch?v=XbGfRWSs-uw
Build on Houdini 20.0.547
sop_qwak.CADuvFIX_MoI5.1.0.hdalc
Cool!
PaQ, would this work with Houdini Apprentice?
It should yes, however the geo output options are quite limited (ROP operators are disabled IIRC). You can only export geo by right click on a node and select export geo ... and in the case of apprentice only .obj works, and I'm not 100% sure uv's are preserved. But I haven't used apprentice since a while !
Show messages: All
1-5
6-13
