When I first saw this Gui mod. I was like that looks so cool. So I bought it on Gumroad. Its the Cherub theme created by Luis Cherubini a high level Blender user. I really like it. I just dig that green. I have been learning so many things about Moi over the last couple years. But one thing that is so interesting to me is understanding how these internal files control the program. Going into the edit ini. files and trying different settings is so interesting. Question? Is there a way I could go into the edit ini. file and change the color of the icons in the Cherub theme. I do have that Moi GUI builder that Chip created. I 'm always so amazed what Moi3D can do. p.s. Does anyone know how that guy.....S2-3D.....youtuber is doing that intersection modeling. I can do the basic modeling technique. But can't quite figure out how to get the history working like in his video. Happy New Year Michael and all other Moi3D users. Wanted to add something. I have been creating many intersection models. And I do know how to tweak the main profile curves and watch them update. But just can't seem to do it like S2-3D... Maybe its the way he edited the video. Just looks so amazing.
Hi Specktech,
Usually icons come from PNG image files and not from a setting in moi.ini, so probably to change the icon color you would need to edit the icon images in a bitmap editing program.
Also one of the new things for the current MoI v5 beta is that there's a built in theme editor now, you can go to Options > General > "Manage themes" and you can then change various UI properties there.
You can get the v5 beta at:
https://moi3d.com/beta.htm
Thanks Michael, I do have version 5. Its really nice. I have been playing around with that gui builder that you put in version 5. I have the "Green Terminal" and the the new "Dark Version" I really have fun seeing all the different combinations of the GUI. Using Moi has made me so curious about Rhino. I will definitly have to get Rhino very soon. I have a trial of 7 and a version of 5. And its so cool the way Moi3D and Rhino communicate. They are like siblings. he he. Thanks for explaning that Gui question. Thanks again Michael. P.s. I read you were thinking of adding a cage edit function in Moi. Did you ever create that function. I figured out a way to do it in moi. But that cage edit in Rhino is very cool. Always admire what you do in Moi3D.
Hi SpecTech,
I haven't created it yet but it's still on my "todo" list.
Thanks, - Michael
I was just peeking at that Gui V5 a little closer. Wow I did not realize you made it so detailed. That is really awesome. Absolutley amazed at the functionality of Moi3D.
I had this question that I can't quite figure out. When I save my files in Moi3D. with the .3dm format.
Now that I have Rhino trial version's loaded. All my Moi files save as Rhino files.
I can save my Moi files as STEP files, to keep them seperate from Rhino files.
I'm still in trial with no save with Rhino. And I always have to right click on my Moi files and select open with Moi. They always get squashed by Rhino.
They always save with the Rhino logo. Sure would like my Moi files to open first priority. And then open with Rhino when I want.
Hard to explain with a few words. Any ideas how to make this work. Thanks so much for all your tips and hard work Michael.
Hi Specktech,
That's something that you set in the operating system to tell it which program you want to handle .3dm files.
The details of how you do it are a little different depending on your operating system, are you running on Windows or Mac?
I'm currently running windows.
Hi Specktech, so on Windows when you right click on the file in a File Explorer window, there will be a menu that pops up which has an "Open with" sub menu under it.
Go into the "Open with" sub menu and at the bottom of it there's a menu item "Choose default program..." . Pick that to open up a dialog that will allow you to set the default program. Set the "Always use the selected program to open this kind of file" checkbox on the dialog.
This stuff is called "File associations" and there is some more info on setting them here:
https://www.lifewire.com/how-to-change-file-associations-in-windows-2624477
Awesome, Thank you so much for that info. I always spread the word about Moi3D. I always tell people to check out that wiki. And Pilou's elephant repository. Thanks again. p.s. I found this podcast that you did about 10 years ago on the internet. So cool hearing you explain your path and about the development of Moi3D. That was a really good conversation. Have a good one Michael.
Thanks! :)
Hi Michael. I was hoping you (or someone else on the forum) could give me some detailed step-by-step instructions on how to install the Cherub theme and icons on Moi3d beta-5 for Mac.
I purchased the package and decompressed it, then copied the files including the font and icon folders to the directories specified in the instructions; googled and followed other instructions; tried everything I can think of but have had no success. It switched to a dark theme and removed the 'Manage Themes' button from the Options menu - but that was all.
Any and all advice would be most appreciated. Cheers, Simon.
Hi Simon,
This might be of interest, later on.
[removed two video links as they may be only valid with older versions v3/v4 and confuse]
"Custom UI Plugin" (not a 'skin' just extra functionality)
https://moi3d.com/wiki/MaxScriptArchive (top of page "customui")
https://www.youtube.com/watch?v=rm1v-PmhKNI
I think you can fairly easy add your icons on the bottom using custom ui.
Hi simonk,
What do the included instructions say exactly?
If it says to overwrite the entire standard UI inside the MOI app itself, that is problematic on any MOI version other than the one they snapshotted from.
Probably that theme pack will only work correctly on Moi version 4.
In Moi version 5 there is a new theme mechanism to improve this exact thing, so you can distribute a theme and switch back and forth between themes without needing to modify the app installation itself.
Yeah that sounds like you're ending up with a UI copied from MOI version 4.
Basically you'll be missing everything that had new UI in version 5.
I'd recommend to only use this package on MOI version 4 and not v5 or later.
Duly noted. Thanks!
