17-23
here i don't kill the fillet object by caution in case of ...as you can see it's some speedy! :)
Very more speedy than your Spaceclaim video! ,)
Seems you don't understand that a function of Unfillet a complex object is not yet easily existing..in Moi or inside some other progs! :)
So we can find some tricky replacements! ;)
I understand it perfectly! That is why I provided a solution to this problem using a third-party program.
That's all.
So you have now 2 solutions !
But SpaceClaim is not a low cost prog...
Yes you are right.
But there is also Plasticity, it is completely free and can also remove fillets.
Not everything is not as cool as SC, but still, still ...
Beta of Plasticity is free yes but final product will more than the 25$ announced because
Kernel Parasolid is used against Kernel C3D! So price will be more than very low cost! ;)
I doubt there will 2 versions Parasolid / C3D but who knows! :)
Wait - and see!
Post your example file. Your spaceclaim video at 1.21 created malformed geometry. Luckily they wanted the entire feature set removed or else, oops!
“Removing holes” is in regards to untrimming trimmed surfaces, which is what spaceclaim is doing there and why it was brought up when you asked about removing fillets. It is the same thing. Not “different”.
17-23
