Full Version: Save image from MOI
Show messages:  1-17  18-37  38-43
26 Jun 2022   [#38] In reply to [#37]
Hi Rudl, I'm not sure if PDF export will have less of a Moiré pattern but it would be worth a try. Give it a try with default settings.
You may need to adjust the image in an image processing program to reduce that kind of pattern, search for something like "Moire pattern removal" to get some information on that.
2 Feb   [#39] In reply to [#5]
Dear ALL!
script: /*! Screenshot Moi Strg+G*/var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 5300, 3560 ); moi.view.lineWidth = 1; }
I have been using this feature for many years without any problems. Now we have noticed on a new PC that nothing or only a transparent background is inserted from the clipboard. What could be the reason for this?
Best Regards,
Franz
2 Feb   [#40] In reply to [#39]
Hi Franz, it is likely to be a problem or limit of maximum texture size in your new machine's video driver.
You could try updating your machine's video driver or lowering the width and height of the requested image down from 5300, 3560 .
What happens if you use this for example:
script: /*! Screenshot Moi Strg+G*/var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 1000, 1000 ); moi.view.lineWidth = 1; }
2 Feb   [#41] In reply to [#40]
Thanks Michael for the quick reply.
Unfortunately, it has nothing to do with that, but maybe it's a setting in Irfan View.
Should Java Script be installed?
My colleague works with Windows 11.
Best Regards,
Franz
2 Feb   [#42] In reply to [#41]
Hi Franz, do you mean that test shortcut above with a 1000 x 1000 pixel size still doesn't work?
And updating the video driver didn't make any difference either?
MOI has JavaScript built in, it doesn't need to be installed separately.
3 Feb   [#43] In reply to [#42]
Hello!
We found the error. It is probably due to the new version of Irfan View.
We have now installed the slightly older version and everything is working again.
“iview452_x64_setup.exe”
Thank you very much,
Franz
