Full Version: Dark Neutral Grey UI Complete with Instructions
Show messages:  1-14  15-34  35-54
15 Nov 2021   [#35] In reply to [#34]
Hi Pieter,
> Thanks Michael but I've already tried that, unfortunately without success.
Can you show a screenshot of where you have placed it?
15 Nov 2021   [#36] In reply to [#35]
Hallo Michael kann es sein das ich noch die 90 Tage Test Version benutze?
15 Nov 2021   [#37] In reply to [#36]
Hi Pieter, it should work the same with the trial version.
16 Nov 2021   [#38] In reply to [#37]
Hello Michael, here is the screenshot (hopefully the screenshot will also work).
-Pieter
16 Nov 2021   [#39] In reply to [#38]
Hi Pieter, I'm able to see your screenshot if I navigate directly to the image URL. I think that service isn't allowing images to be hotlinked from another web site.
So anyway yes that looks like you've got it in the correct place.
What does the place where it is supposed to show up look like? Is there a placeholder icon there? If not then there is probably another file that also needs to be updated to set up the button that then wants to use the image.
16 Nov 2021   [#40] In reply to [#38]
Hi Pieter, I think the file that uses the image is ViewControls.htm , so update that file as well, in the same folder.
16 Nov 2021   [#41] In reply to [#40]
it worked now my moi is complete, you are my hero many thanks for your effort and patience !!!
Many greetings
Pieter
17 Nov 2021   [#42] In reply to [#20]
what do you mean when the Moi v 5 is to be bought?
-Pieter
18 Nov 2021   [#43] In reply to [#42]
HI Pieter, sorry I don't have any idea yet when v5 will be released. The beta test period hasn't even started yet but that should get going pretty soon.
7 Dec 2021   [#44] In reply to [#33]
I tried the installer and it worked.
But there are number of things I need to bring over from the existing MOI setup.
So for now I renamed the MOI AppData folders and my MOI was back EXCEPT it was still a dark scheme while mine was light.
What controls that?
Thanks much. Great work.
Frederick
7 Dec 2021   [#45] In reply to [#44]
Hi Frederick, that would be primarily controlled by the moi.css file inside the UI subfolder in the install. Try restoring that file back to the default version.
10 Dec 2021   [#46] In reply to [#45]
Yup,
just copy the original Moi.css (and maybe Moi.ini if you wan that too) from the (appdata/moi/ui directory back to the (appddata)Moi directory, i.e. one level up from the ui directory.
(The original Moi directory is the "Moi - Copy" directory that the installer created and backed up all your original moi stuff into)
15 Dec 2021   [#47] In reply to [#46]
Thanks.
To undo the install just for now I renamed the Moi folder to Moi - DARK and the Moi - Copy folder to Moi.
There is no UI folder in the Moi folder.
Frederick
2 Jan 2022   [#48] In reply to [#47]
After I copied the .css file to MOI program directory (UI) I always get this error, how to fix?
https://i.imgur.com/gjlk7Ci.png
2 Jan 2022   [#49] In reply to [#48]
Hi jabber, see earlier in this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10465.27
http://moi3d.com/forum/index.php?webtag=MOI&msg=10465.28
5 Aug 2023   [#50]
And the Linux guy shows up late to the party looking for a Dark UI.
I'll wait. :P
Chris
5 Aug 2023   [#51] In reply to [#50]
Hi Chris,
> I'll wait. :P
You don't have to wait, it is a built in feature for v5.
You can get the V5 beta at https://moi3d.com/beta.htm and then from Options choose "UI Theme: Dark".
5 Aug 2023   [#52] In reply to [#51]
Thanks Michael. This alone is worth the price to get v5. It works a treat in Ubuntu MATE.
Chris.
Message 10465.53 was deleted
11 Aug 2023   [#54]
