7-26
27-46
47-49
Hi Dejan,
> Is is somehow possible to change colour of construction lines?
Yes, you can set the color in moi.ini, go to Options > General > "Edit .ini file" button, and then inside moi.ini find the [Drawing Aids] section and there's an entry in there for "StraightSnapLineColor" like this:
[Drawing Aids]
StraightSnapLineColor=103,0,0,0
That takes 4 comma-separated values which are for Opacity,Red,Green,Blue - the values can range from 0 to 255.
That controls the color for both construction lines as well as the straight snap lines that show when straight snap is engaged.
Thank you Michael! Your support here is absolutely amazing :-)
Cheers,
Dejan
Hello! Responding to a very old thread, as I'm trying to get this working again in the current beta. I've found that some bits of the UI language have changed a little, but that was all easy to fix up. You can find an updated version at
https://dymaxion.org/tmp/ConstructionLine.zip
7-26
27-46
47-49
