Full Version: Construction line script
Show messages:  1-4  5-24  25-44  45-49
27 Feb 2016   [#45] In reply to [#44]
ALL is done! ;)
25 Jun 2017   [#46]
Is is somehow possible to change colour of construction lines?
Cheers,
Dejan
25 Jun 2017   [#47] In reply to [#46]
Hi Dejan,
Yes, you can set the color in moi.ini, go to Options > General > "Edit .ini file" button, and then inside moi.ini find the [Drawing Aids] section and there's an entry in there for "StraightSnapLineColor" like this:
[Drawing Aids]
StraightSnapLineColor=103,0,0,0
That takes 4 comma-separated values which are for Opacity,Red,Green,Blue - the values can range from 0 to 255.
That controls the color for both construction lines as well as the straight snap lines that show when straight snap is engaged.
26 Jun 2017   [#48] In reply to [#47]
Thank you Michael! Your support here is absolutely amazing :-)
Cheers,
Dejan
20 Dec 2025   [#49]
Hello! Responding to a very old thread, as I'm trying to get this working again in the current beta. I've found that some bits of the UI language have changed a little, but that was all easy to fix up. You can find an updated version at https://dymaxion.org/tmp/ConstructionLine.zip
