Full Version: Construction line script
Show messages:  1-20  21-40  41-49
26 Feb 2016   [#41] In reply to [#40]
Maybe it is not different from "Helper Line". I don't know.
I found this script by clicking here :
Edit : Before translating , I took a look at your website to see if maybe you had already done that! :)
(There is a lot of information on your site! )
26 Feb 2016   [#42] In reply to [#41]
Section Divers Done! :)
http://moiscript.weebly.com/liste-scripts-commandes.html
J'attaque la section Scripts! :)
In fact Constructions Line is exactly like Helpers Lines except the fact they stay living !
And die when you want!
26 Feb 2016   [#43]
Section Scripts Done!
Big Section Maths for tomorrow, but many commands are yet translated on my site
so just move the files for update this crazzy Icons' list on the Task bar! :)
Bravo to Marco!
27 Feb 2016   [#44] In reply to [#43]
I can help you Pilou , if you want.
Bear
27 Feb 2016   [#45] In reply to [#44]
ALL is done! ;)
25 Jun 2017   [#46]
Is is somehow possible to change colour of construction lines?
Cheers,
Dejan
25 Jun 2017   [#47] In reply to [#46]
Hi Dejan,
Yes, you can set the color in moi.ini, go to Options > General > "Edit .ini file" button, and then inside moi.ini find the [Drawing Aids] section and there's an entry in there for "StraightSnapLineColor" like this:
[Drawing Aids]
StraightSnapLineColor=103,0,0,0
That takes 4 comma-separated values which are for Opacity,Red,Green,Blue - the values can range from 0 to 255.
That controls the color for both construction lines as well as the straight snap lines that show when straight snap is engaged.
26 Jun 2017   [#48] In reply to [#47]
Thank you Michael! Your support here is absolutely amazing :-)
Cheers,
Dejan
20 Dec 2025   [#49]
Hello! Responding to a very old thread, as I'm trying to get this working again in the current beta. I've found that some bits of the UI language have changed a little, but that was all easy to fix up. You can find an updated version at https://dymaxion.org/tmp/ConstructionLine.zip
