Full Version: Construction line script
Show messages:  1-2  3-22  23-42  43-49
12 Oct 2007   [#3] In reply to [#2]
> Is not possible to mask Helpers Lines temporalily?
Not currently. However, I will make one small change that will make it possible for the next patch.
12 Oct 2007   [#4] In reply to [#3]
So near the perfection :)
12 Oct 2007   [#5] In reply to [#2]
Hi, Pilou,
I don't see a way currently to hide the lines, there's seems to be a .hidden property for them, but it doesn't affect the visible display of the lines.
For the delete commands, the script has to be rerun or maybe setup like this in the Options dialogue to delete with no gui :
K ConstructionLine
delete last line:
Alt+K script:var gd = moi.geometryDatabase; var clines = gd.getObjects().getConstructionLines(); if ( clines.length > 0 ) gd.removeObject( clines.item(clines.length-1) );
delete all lines:
Ctrl+K script:var gd = moi.geometryDatabase; gd.removeObjects(gd.getObjects().getConstructionLines() );
Hope that helps --
Paul
PS --- I see Michael beat me to it. Disregard mine :)
12 Oct 2007   [#6] In reply to [#5]
Yup, this is the part that I have tuned up for the next patch, it will now pay attention to the hidden property on a construction line.
12 Oct 2007   [#7] In reply to [#6]
Just some stuff I noticed... when I was messing around with this I noticed that after the lines are built and the script exited, the lines can be deleted one by one by doing a mousedown, drag, mouseup, and the line is apparently deleted.
I don't know if that's a bug or not, but if it is, it's maybe a "good" bug.
Also, setting the .hidden property at the end of the script, disables that drag deleting behavior, apparently because the lines are marked hidden, but still on screen, the snapping function still works, which could prevent an inadvertent line deletion.
Paul
12 Oct 2007   [#8]
And possibility to save the Helpers lines in a file?
12 Oct 2007   [#9] In reply to [#7]
Hi Paul,
I see - what's happening here is when you click down on a construction line it is getting selected (even though the appearance does not change), and then it is trying to drag it like a regular object. However, clines don't support some of the other infrastructure for getting transformed yet, so that's why they get deleted. But this is easy to tweak, I've tuned this up so that the line will actually drag in this situation (and you can also apply any of the transform commands on them).
You can still remove it by clicking it and then using Delete.
But these are some of the reasons why there isn't an "official" persistent construction line yet - you probably don't want them to get selected like regular objects, but there isn't currently any way to lock an object to prevent it from being selected and still remain snappable.
12 Oct 2007   [#10] In reply to [#8]
This one will have to wait for V2...
12 Oct 2007   [#11] In reply to [#9]
I see, interesting. Thanks for the explanation. Sounds good to me!
Paul
12 Oct 2007   [#12]
An other Helper lines like circles, arc, rectangle...? ;)
12 Oct 2007   [#13] In reply to [#12]
I haven't been planning on it, that would tend to add quite a lot of extra commands.
A construction line is kind of a special case since it extends infinitely in either direction unlike a regular line. So it offers something extra than just a regular line.
A "construction circle" wouldn't really offer anything similarly extra to a regular circle.
In version 2 I would like to make it possible to lock objects to prevent them from being selected, but remain snappable. At that time you would be able to draw a circle, set it to have a dashed line style, and then lock it and that would end up being the same thing as a construction circle.
12 Oct 2007   [#14]
And on the silly side of things.....
If someone's got the AutoRotate2 script installed, here's a time waster :
activate the construction line script
draw a few lines in each viewport
click a viewport to keep the lines and exit
maximize the 3d viewport
turn on the autorotate2 script
and it's
MoI -- "It's a screensaver too!"
Paul
15 Nov 2007   [#15] In reply to [#13]
@ Paul,
Another excellent script here ! It's really cool to have permanent construction lines ! ;-)
@ Michael,
Yeah ! Good idea. It's similar to a feature in Illustrator. I'd really like to see your "feature list" for V.2... ;-))
10 Jun 2009   [#16]
So, it's been quite a while and I'm assuming the code has bit-rotted a bit, but I'm trying to use the ConstructionLine.js script from this thread, and when I try to launch it, I get a JScript error, "Object expected Line 6: Column 1". I'm fairly certain it's set up correctly, and I can't figure out which line it's talking about. Ideas?
/Ella
10 Jun 2009   [#17] In reply to [#16]
Hi Ella - which version of MoI are you trying it on?
I just tried it over here with the latest v2 beta (Apr-12-2009 release) and it seems to work fine for me.
You mentioned the "ConstructionLine.js" script - do you mean you only have that one file? There should be 2 files included in the .zip, a .js file and an .htm file.
You'll need to copy both of those files (not just the .js file) to your \commands sub-folder, then set up a shortcut key that says: ConstructionLine as the command.
Let me know if you've done all that and still have problems.
10 Jun 2009   [#18] In reply to [#17]
Current beta. I was trying to link to the command as "ConstructionLines.js"
Here's a slightly cleaned up version of the code script, with instructions for adding it to a conveniently empty slot in the "Edit" tab.
It'd be nice to have a "Done" button for the script, instead of the "click on the viewport" bit, which is a bit too easy to trigger accidentally. I know this is kind of abusing a line factory to make things work; is it possible to create that behavior?
EDIT (7/11/2015): The attached instructions are for v2 - for MoI v3 the way icons are set up on buttons is slightly different and so for setting up the button in v3 put in this instead:
<td><moi:CommandButton icon="icons/CLIcon.png" command="ConstructionLine">CLine</moi:CommandButton></td>
ConstructionLine.zip
10 Jun 2009   [#19] In reply to [#18]
Hi Ella,
Give the version attached here a try - I added a Done button to this version. This one won't exit if you just click with a left-click, you end it by clicking the Done button or using one of the shortcuts for Done (right-click in a viewport or the Enter key).
The line factory part wasn't actually doing anything here, I think it was some left-over remnant from this having started out originally as a modification of the line command or something like that.
The actual meat of creating the construction lines was happening inside the GetPoint() call, which is set up to wait until a point is picked and then return. In this version I replaced that call to a manual event loop so it can respond to getting the "done" event.
Let me know if this one doesn't do what you wanted.
constructionline2.zip
11 Jun 2009   [#20] In reply to [#19]
Ah thank you Michael! The script and instructions worked flawlessly for me (an HTML challenged soul). THis will help enormously with my current projects. Will this CLine script function/feature become a permanent part of MoI going forward or will it remain an end-user add-on?
11 Jun 2009   [#21] In reply to [#20]
Hi Satoribomb, I'm glad you got it all set up!
At the moment I'm just planning on having this as an optional add-on. In the future I would like to make it easier to manage plug-ins though.
12 Jun 2009   [#22] In reply to [#19]
Yes, it's great! Thanks for the update. One more question -- is it possible to have undo work while editing CLines? I.e., I lay down two lines, hit undo, have the most recent one go away, and then lay down another?
