Full Version: MOI5 Wish list
Show messages:  1-15  16-35  36-50
3 Oct 2021   [#36] In reply to [#34]
Here's hoping! :D
4 Oct 2021   [#37]
Can we have something like this, please. A quick way to exchange the two values when using the chamfer tool.
4 Oct 2021   [#38] In reply to [#37]
Hi 3image,
Update the MoI v4 Chamfer.htm and Chamfer.js (in the install's commands folder) with the attached versions and also put the attached Swap.png inside the install's ui folder.
That should then give you a swap button like this:
Chamfer.htm
Chamfer.js
4 Oct 2021   [#39] In reply to [#38]
Very cool! :)
5 Oct 2021   [#40] In reply to [#38]
That is so cool, Michael, thank you very much. I've missed something like this for years and finally decided to write a proposal in the forums.
5 Oct 2021   [#41]
Seems very cool indeed! ;)
17 Oct 2021   [#42] In reply to [#25]
'Quite often after creating the object from curves I want to do some operations using edges. And as I have curves in the same area I have to hide curves first. This quickly gets annoying.
In Rhino we get a little pop-up when there are multiple objects in the same place so the user can pick the desired one. That, or some setting which would allow you to define priority (for example edges over curves) would be great.'
Revit has a function where you just hit 'tab' and it cycles through the objects the mouse is hovering over. I miss it in other softwares...Very very handy, quick, and yes far less intrusive than the Rhino pop-up...
- Rich
1 Nov 2022   [#43] In reply to [#21]
How can I setup Screenshot upon Save, in the meantime?
1 Nov 2022   [#44] In reply to [#43]
Hi Mindset,
I've got filesystem plugins for showing .3dm thumbnails implemented for the next v5 beta, I'll try to get it wrapped up soon.
1 Nov 2022   [#45] In reply to [#44]
WOW❗
6 Nov 2022   [#46] In reply to [#45]
The menu bar can be customized to add plug-in functions?
6 Nov 2022   [#47] In reply to [#46]
Hi feirui445, there is a UI Mod that you can install that adds those buttons:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
http://moi3d.com/wiki/MaxScriptArchive
6 Nov 2022   [#48] In reply to [#47]
you can click an Add button, the commands folder will be displayed. If you select a plug-in, it will be displayed on the menu
13 Nov 2022   [#49]
Would love to see MoI get MDI tabs….
11 Sep   [#50]
Please add "Edit points" and "Point objects" as children of "Points" in the Types area of the browser. I find myself wishing that I could filter window selection to just edit points.
- Peer
