Full Version: V5 Wish List
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  656
25 Mar 2021   [#96] In reply to [#94]
Very nice. Was it hard to do it? Have you used some additional plugin for that or only pure Blender?
25 Mar 2021   [#97] In reply to [#95]
I like it much but it looks very complicated to build from scratch, especially in French :)
I look for similar solution for making mechanical animations/simulations like that but I would like to see it more straightforward for "sunday" mechanical animator where buttons help you choose presets and leads you to the goal without braining too much ;).
https://www.youtube.com/watch?v=kWtekHNl894
25 Mar 2021   [#98] In reply to [#85]
I like the suggestion by mdesign above to use Folders as a grouping mechanism. Seems like it would fit in well with the existing UI.
For example, I'm currently modeling a car in MoI. Each wheel has 56 spokes, a rim, a hub, a cap and a tire. Sixty objects, currently assigned to 5 colors.
Would be great to group those into a Folder called Wheel. Ability to Lock/Unlock & Hide/Unhide as usual. If un-locked, any Alignment Tool applied to the Folder would automatically default to "Move as Group".
If we had sub-folders, each of the 4 wheel folders could be in a folder called Wheels.
And as mdesign suggested, folders would be great for consolidating and holding extrusion curves, cutting objects, trimming curves, etc.
25 Mar 2021   [#99] In reply to [#96]
100% Blender, no plug in or add-ons
No bones ik, just constraints
25 Mar 2021   [#100]
As we have SKP format export inside Moi...
Last version of a powerful free Version of SKetchUp is the 2017 Make!
You have a cool animation Plugin inside Sketchup! ;)
Animator by a French guy Fredo6 ;)
Some rustic UI but very efficient!
25 Mar 2021   [#101] In reply to [#99]
Thank you for letting me know.
Cheers!!!
26 Mar 2021   [#102] In reply to [#82]
@Pilou >You have yet the solution to make a little text file list with any function
then Copy Past the function that you want after the Press TAB! ;)
Rustic but efficient :)
And no problem of memory headache :)
Touche(s) de raccourci :shortcut keys ???! hotkeys, Short!,
The goal is short and quick.
-Zooen
26 Mar 2021   [#103] In reply to [#102]
Yes shortcuts win some times but put all functions in a shortcut is not valid for old brain! ;)
Over 6 shortcuts is a limite for me! :)
26 Mar 2021   [#104]
What is your count of shortcuts in Blender?
26 Mar 2021   [#105] In reply to [#104]
I am not genetically modified for Blender! :)
26 Mar 2021   [#106]
previs of boolean difference, amount of cut
1 Apr 2021   [#107] In reply to [#91]
In Rhino forum one guy posted script for mating: https://discourse.mcneel.com/t/how-to-align-two-objects/121132/32 You can see also how it works in video here.
It`s quite short and simple script. Your method is wonderful I`m only sharing it because it`s in same topic as we talked previously. Maybe it will help somebody to write similar script for MoI (if it will be needed of course).
Cheers!!!
1 Apr 2021   [#108] In reply to [#107]
You have the same with native Transform / Orient / Orient or Line Line ! ;)
May fbeew clickc more but...
1 Apr 2021   [#109] In reply to [#108]
What is line-line? Have you meant line-line drag and drop constraint?
1 Apr 2021   [#110] In reply to [#109]
Yes with only 2 Points as Start and 2 Points as Target + Helpers lines you can make anything you want with the fabulous Line-Line !
( + some parameters if you want Uniform, Stretch, None) , Copy or not )
1 Apr 2021   [#111] In reply to [#110]
Thanks a lot. I haven`t known that too :)
1 Apr 2021   [#112]
Good day.
1.I would like to see the ability to apply a materials to an object like its done in sketchup...not rendered as in keyshot etc but as a sketch would be more than usefull to me.
2.Parametric style editing if possible...sometime if I need to change something that is already done it is not easy.
Tnx.
2 Apr 2021   [#113] In reply to [#1]
> // few number record
How about a setting for how many to keep and listing them in a drop list?
2 Apr 2021   [#114]
Shortcut Keys; Options Tab
1. Import / Export
2. Search
3. Upon "Add", warn if key-combo is already in use.
Thanks Mike for all that you do!
7 Apr 2021   [#115]
I would love to see the introduction of a simple clipping plane (section plane) for sectional analysis of a model, would be hugely beneficial as it is in SketchUp
- Rich
