Full Version: V5 Wish List
Show messages:  1-2  …  563-582  583-602  603-622  623-642  643-656
11 Aug 2024   [#623] In reply to [#617]
Hi stefano,
> In the new object details / user text:
> Can "add" button be always set to append?
It's set up to work the same as the keyboard shortcut list.
When you add in a new one it's put at the top because that's closest to the "Add" button. It makes it easier to see what is going on as a result of pushing the button.
The next time the dialog is opened they will be displayed in alphabetical order, not in the order they were added.
> Alternative feature consideration: up/down arrows
> could re-order the key values ( data rows ).
To keep it simple it just uses alphabetical ordering.
11 Aug 2024   [#624] In reply to [#618]
Hi stefano,
> FROM...SCENE BROWSER / OBJECTS
> Implement a way to jump straight into "DETAILS" of the object
> from the scene browser, maybe right click, double click
> or treble click. Does not matter how, matters its quick.
> Result: Save users going to select objects on screen
> and go to top right of interface "details button".
You can set up a keyboard shortcut to open the "Details..." dialog by putting in this for the "Command" part of the shortcut key:
script: /* Show Details... */ moi.ui.createDialog( 'ObjectPropertiesDialog.htm', 'resizeable,defaultWidth:700,defaultHeight:500' );
The Detailed object properties dialog shows the properties of the current selected objects.
If you want an item in the scene browser to become the single selected object you can do that by right clicking on the selection dot.
A left click on the selection dot in the scene browser toggles selection of just that object on or off without changing any others. A right click selects that item and deselects everything else.
So with this set up you would do a shortcut key and then a right click on the scene browser item, you won't need to select in the viewport or move your mouse to the "Details..." button.
11 Aug 2024   [#625] In reply to [#621]
Hi Chri,
> it would be good to be able to export in SKP version 2017 which is the latest free version of SKETCHUP.
In MoI v5 there is a setting in moi.ini that you can use to control the version of the SKP file.
It's under:
[SKP]
SUModelVersion=Current
Try setting that to:
SUModelVersion=SU2016
The allowable versions are slightly different between the Mac and Windows MoI versions, on Mac you can set it to SU2017 and up to SU2021
On Windows currently the max is SU2016, I'll see if can remove this different limit for Windows.
11 Aug 2024   [#626] In reply to [#624]
thanks for the clarifications Michael - makes sense !
12 Aug 2024   [#627]
Hi, Michael
Can we have z axis in custom CPlane always pointed to 'the sky' (absolute above) in 3D view? That's we keep the 'Rotation Style' to 'Rotate around world Z axis' within Options > View > Rotate/Pan/Zoom Options menu.
in this screenshot, the selected face will be better if facing to the sky in 3D view, i.e.: the TOP of cplane becomes the world z axis (temporarily), or in simple way: the z axis locked as the vertical axis in custom cplane 3D view.
The current state is quite 'dis-orienting' when we rotate the view around. And even better, the '3D' label will go like '3D (cplane)' like the other ortho views.
I do hope i've made myself clear.
Thank you very much in advance and pardon my English.
Cheers.
12 Aug 2024   [#628] In reply to [#625]
HI Michael
Setitng SUModelVersion=SU2016 works fine
thanks tou very much for your help and this magnificent soft
chri
14 Aug 2024   [#629] In reply to [#622]
Thanks Pilou
Excuse me, I hadn't seen your reply.
Merci Pilou
Excuses moi, je n'avait pas vu ta réponse.
chri
14 Aug 2024   [#630] In reply to [#629]
@ Chri C'est une sorte de moulinette à formats très pratique!
Et son catalogue "mondial" d'objets en direct est un must! ;)
Free Pconplanner
Multi formast converter very useful!
And objects catalog in diect a must!
18 Aug 2024   [#631]
Hi, Michael...
Haven't heard from you for several days now.
We're sincerely hope you're doing just fine.
q'_'p
EDIT : NVM... Found you in other thread. ^^
18 Aug 2024   [#632] In reply to [#631]
Hi Elang, I have implemented a new viewport rotation mode "Rotate around cplane z axis" which I hope will do what you were asking for above.
Thanks, - Michael
18 Aug 2024   [#633] In reply to [#632]
Very much appreciated, Michael !
Thank you very much.
You're the best. *thumbsup*
PS: I assume it will be available in the next beta release?
18 Aug 2024   [#634] In reply to [#633]
Hi Elang, you're welcome!
Yes, that's correct. It will be a new option under Options > View > Rotate/Pan/Zoom options > "Rotation style".
18 Aug 2024   [#635]
I have a couple of tiny wishes but hey it's a wishlist.
1. by default not having the ratios linked on new objects (maintain proportions) when you want to change the X axis length for instance. Always another click to turn that off and think it should be off to begin with. Think most users rarely make squares vs rectangles.
2. Sure there is a hotkey but switching units e.g. inches to millimeters would be great as a button in gui. Sometimes if you undo halfway, the object will not scale back or forward to what it should be (gets stuck trying to scale to new base unit). I have it always set that I can work in realworld scale and if I want to model in inches, the model scales from metric to imperial without physically changing it's size. Not sure why anyone would ever want different.
3. I like that if I'm in inches I can still input Xmm's and that adjusts and vice-versa . However most people are measuring a diameter as opposed to a radius. For instance when putting a caliper to something. I wish diameter was the default and I wish I could input while in inches as my base unit ~ 50.8mm/2 or 25.8mm*.5 or 25.4mm_D for diameter or have a simple toggle in that field that activates diameter input instead of radius.
Love moi for many years :)
18 Aug 2024   [#636] In reply to [#635]
Hi co3Dprints,
If you put the attached file SetEditSizeMenuUniform.js into the appdata startup folder, you should then have "Maintain proportions" unchecked initially.
> as a button in gui.
It's in the UI under Options > General > "Unit system" .
You can make diameter the default by editing moi.ini (Options > General > "Edit .ini file" button) and set:
[Commands]
UseDiameterDefault=y
> <....> or have a simple toggle in that field that activates diameter input instead of radius.
There is a toggle for switching a radius field between radius or diameter input by clicking the label with the "cycler" arrow to the left of the field:
Hope that helps!
18 Aug 2024   [#637] In reply to [#636]
Wow, so versatile. I took a deeper dive on moi settings years ago but wrongly, just figured it wasn't customizable on the gui items I was asking for. Excellent and thanks for showing this!
Love this app.
Jason
18 Oct 2024   [#638]
Hey Michael,
Any chance to get depth/height map output?
Also, hoping to get "Save custom CPlane(s)"
http://moi3d.com/forum/index.php?webtag=MOI&msg=10744.3
This would be great because I was trying to model an articulation along the array with RotateArray; items on & along a conveyor being the example.
If a "Plane Object" could be part of a group, for instance, and RotateArray could accept it as an argument, then it could be repositioned with an initial call and subsequent RotateArray calls could pick-up the cause.
Additionally, it would indeed be wonderful if RotateArray could also work with circular arrays.
Truly LOVE your software!
Many thanks,
Moi Bueno
MindSet
18 Oct 2024   [#639] In reply to [#638]
Hi MindSet,
That's usually a rendering type function but currently MoI doesn't try to do rendering.
> It would indeed be wonderful if RotateArray could also work with circular arrays.
It should be working with circular arrays. It needs a point object to be included with the array, are you possibly missing that?
Here's what I tried - Circular array:
With RotateArray applied:
12 Jun 2025   [#640]
Tab or some other key code to skip through items under the cursor to select elements that are in the same plane or under each other...I got rid of horrible horrible Revit years ago but still miss this feature!
// Rich
15 Jun 2025   [#641]
My personal wish list contribution is for the SVG export feature to have an option for users to choose whether they want the exported item to be outlined, solid, or both, with "outline + solid" being the default.
Just a suggestion.
EDIT FOR EXPLANATION: As SVG files are comprised of markup code, I have a feeling it'll be as easy as changing a few lines to reflect whether the shape is outlined, solid, or solid with an outline. Granted, straight-line shapes - and open curves in general - might have to be outline only so that they show up in a software program.
17 Jun 2025   [#642]
My personnal request for the roadmap.
Have options for import obj files (SubD/Create/From file).
- rebuild the surfaces (yes/no)
- Apply a Subd (yes/no)
I know the fonctionnality is in subd but it is an import Obj feature too.
This is why I think applying subd could be an option.
Best regards
