Full Version: V5 Wish List
Show messages:  1-11  …  312-331  332-351  352-371  372-391  392-411  412-431  432-451  …  652-656
25 Apr 2022   [#372] In reply to [#371]
Hi Flowgun, no problem. Yes MoI v3 used an older interface for the file open dialog on Windows. MoI v4 was updated to use the latest.
> tbh, I still use MoI v3 mostly since I encounter performance problems with v4.
Do you still see the performance problems with v5?
There is also a setting in v5 to make it use the same Direct3D9 system graphics library that v3 did, you can set that in moi.ini under:
[View]
GraphicsAPI=Direct3D9
If you have a pretty old flaky video driver that worked better with MoI v3 that could make v5 behave more like v3 on your system possibly.
29 Apr 2022   [#373]
When saving as a PDF, I wonder how hard it would be to offer the option to append a new page if the PDF already exists? For me the use case would be the many times that I'm appending the PDFs of different views of something to produce a document to share. If it is not too difficult, I would find this quite handy!
I realize that PDFs are complex, so if it would make such a feature simpler to implement, maybe the option is only offered if the existing PDF is "easy" to work with, for example created by MOI?
--Larry
29 Apr 2022   [#374] In reply to [#373]
Hi Larry,
For this use it seems like it might work better if you could generate the multi-page PDF all in one go from some kind of list of saved views.
I think it might be possible to make a script that would do a "save to PDF append page" if I can set up a helper utility program for it to call to do the merge. The PoDoFo library that MoI uses for PDF handling has a utility like that in it so I'll give it a try.
30 Apr 2022   [#375] In reply to [#374]
Assembling the individual PDFs into a multi-page document isn't a problem for me (just a small hassle),
but the thought occurred that if it was relatively easy to append to an existing PDF it would be quite
handy. I'll look forward to whatever you come up with & appreciate as always your willingness to help!
--Larry
30 Apr 2022   [#376]
"Wish" list....
Continuity controls added to sweep curves and rails.
Sortof the same work as 4 sided continuity added to network and nsided.
30 Apr 2022   [#377] In reply to [#374]
Michael
I know it is very early days yet with development of V5, and I'm unaware the your plans for GUI improvements. Although the view window buttons on the bottom nav bar function well, I wonder if there is a more elegant solution that doesn't hog so much screen realestate.
Although the colours are a bit garish, I think the navigation cube in this online SD modeller could serve as an example:
https://stephaneginier.com/archive/nomad_demo/
The navCube is immediately comprehensible on initial encounter with the interface and the labelling of faces greatly assists with orientation.
It also includes screen reset facility: clicking a second time on the cube face selection zooms to selected object extents.
Now, I know that there is no option for split screen, but perhaps a small adjacent 4 pane window icon could solve this requirement.
Please disregard this suggestion if it does not meld with your vision of Moi3d
30 Apr 2022   [#378] In reply to [#377]
Hi James,
> elegant solution that doesn't hog so much screen realestate. Although the colours are a bit garish,
It looks like it performs a somewhat different function than the Split / 3D / Top / Front / Right view tabs in MoI.
When you click on Top on that view cube, it's navigating a perspective view camera position. When you click on
the Top view tab in MoI it switches the orthographic 2D Top viewport to be maximized.
The 2D ortho views in MoI help to give more of a 2D drawing workflow when you're working in them, it would
be a problem to eliminate them and only navigate the 3D perspective view like the view cube navigation
is doing.
30 Apr 2022   [#379] In reply to [#378]
Michael
is doing.
Of course, I wasn't advocating abandoning 2D orthographic projections, but rather suggesting the possibility of adapting this type of navigational device to operate within MoI3d similarly to how the button row works now (perhaps with animated transitions).
And as for the 4up split view, this could be handled by additional adjacent icon.
Anyway it was only a thought, not even a request.
Have a great weekend,
30 Apr 2022   [#380] In reply to [#379]
Hi James, I think it might be difficult to animate a transition between perspective and orthographic. I'm not sure though.
The way that particular view cube navigation works it isn't an issue because it stays in a perspective view the whole time. That's why it's a somewhat different type of function than MoI's view tabs.
Another issue is that in MoI when you switch to a 2D ortho view you don't do any view orbiting. With the view cube you need to be able to orbit the camera to expose different views that you might want to switch to. All the different views are not always exposed and ready to click on immediately, like if you go to Top it's kind of problematic that the view cube now just shows Top where you're already at and you have to do some camera orbiting movement to be able to go somewhere else.
It doesn't really fit in with MoI's 2D viewports being separate from the 3D view. That's why I mentioned getting rid of the 2D ortho views, because it seems like that would probably be a precondition for making it work.
30 Apr 2022   [#381] In reply to [#375]
@Larry,
re :
I put a plug-in for doing this over here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10679.1
1 May 2022   [#382] In reply to [#378]
Am I am not even sure why one would need the cube. Got all of it already in the tabs ...
Message 10114.383 was deleted
1 May 2022   [#384]
A circular selection mode would be helpful
2 May 2022   [#385] In reply to [#381]
AddPageToPDF.js with podofomerge works great with V5 beta, thanks!!
A little odd though as it appears to work with V4 (script functions as it does in V5, with no errors), but the output file is not changed.
I'm on a MacBook Pro with M1.
--Larry
2 May 2022   [#386] In reply to [#385]
Hi Larry,
I've updated AddPageToPDF.js so it should work ok now on v4 Mac now as well.
It was an issue with spaces in filenames that v5 automatically compensates for.
2 May 2022   [#387] In reply to [#386]
Confirmed working, thanks again!
--Larry
7 May 2022   [#388]
Feature request for V5... add dimension field to POLYGON data entry fields
I would to be able to:
1. select POLYGON
2. select the desired option (Center, Edge, Star)
3. enter the desired number of SIDES (sidebar question... can the default number of sides by set in the .ini file?)
4. tab to a new 'dimension' field (below the SIDES field?) to enter the desired polygon dimension (eg, the CIRCUMSCRIBED dimension if selected). I'd also prefer to have the entered dimension match my USER PREFERENCES for DIAMETER vs RADIUS or vice versa, eg, use DIAMETER if CIRCLES is set to use DIAMETER (or provide an .ini option to set the preferred default).
For example, if I'm using the current implementation correctly(?) for a CENTER drawn polygon, the TAB button cycles between SIDES and CIRCUMSCRIBED. To enter the desired CIRCUMSCRIBED dimension, I have to move the cursor to the XYZ data entry box to enter the desired dimension. Or create the polygon and then edit the dimensions.
Obviously not a significant change functionally but would potentially improve my workflow when creating polygons.
Thanks as always for this great CAD program!
Scott
7 May 2022   [#389] In reply to [#388]
Hi Scott,
The default comes from this line in the Polygon.htm file inside the commands install folder:
<td><moi:UnsignedIntegerInput id="numsidesinput" default="5"/></td>
You could change that to default="8" for example.
Another thing you can do is set up a shortcut key which will set it to a particular value. For
that you would put in this for the shortcut key:
Polygon numsidesinput=9
Yes you need to set distance constraint to control it currently, by entering the distance value in
the XYZ (or "d") input control like you describe.
The main reason why the polygon command doesn't have a radius input field is that it's not fully
defined by a radius value alone, it still needs a point to be placed to control the orientation of
the polygon.
I guess it could be possible to have a radius/diameter field there which would do the same thing
as setting distance constraint. One thing that's potentially problematic with that though would
be that there would effectively be 2 different spots where you would be setting distance
constraint and what should I do if you enter in a different value in one control vs another.
Another thing I've been meaning to set up for some time is a shortcut that would put focus in the
XYZ control always and not in the command option fields like Tab does. Like maybe Ctrl+Tab.
7 May 2022   [#390] In reply to [#389]
So with regards to modifying the polygon.htm file....
MoI's structure is that the htm and js files have the same name to address each other.
I just wanted to be sure. Or possibky suggest a pointer in an htm file to a js file.
So why i ask, is "i" would make a polygon3-polygon5 and polygon8 htm file etc. As many as i like, though they all only really need polygon.js
Not more js files just for the name match.
But really, its not overly intrusive. Just wanted to ask about if it worked that way now, and i didn't know it
7 May 2022   [#391] In reply to [#390]
Hi Burr, so the way that commands in MoI work is when you enter in a command name to run, MoI will look in the commands folders (both install and appdata and any additional ones listed in moi.ini) for a .js script file with that name.
There can optionally be an .htm file with the same name as well. If there is then it will start up loading the .htm file into the command options area and let that finish loading first before loading and executing the .js file's script code.
It won't work like that because the .js file is the main thing associated with a command, it's the .htm file that is optional. If you have a command that does something and exits without showing any UI then only the .js file is needed.
Instead of doing that you could give a command line parameter and have the script pay attention to that to parameterize it.
There is also a mechanism where if you give a command line parameter using the id values of one of the controls in the .htm file it will set the control to that value. So for example instead of having polygon3.htm, polygon5.htm, polygon8.htm you could do:
Polygon numsidesinput=3
Polygon numsidesinput=5
Polygon numsidesinput=8
