Full Version: V5 Wish List
Show messages:  1-2  …  143-162  163-182  183-202  203-222  223-242  243-262  263-282  …  643-656
29 May 2021   [#203] In reply to [#202]
Something like this? But without the text.
29 May 2021   [#204] In reply to [#203]
A take on Ed's suggestion
MindSet
30 May 2021   [#205] In reply to [#203]
I've tried to let these sink in for a bit but they're still seeming kind of weird.
30 May 2021   [#206] In reply to [#205]
2 Jun 2021   [#207]
It would be nice to have 2d blend that would work on any part of the curve instead of just the endpoints.
An option to trim at that point would be interesting also.
Also, a function to directly cut a line at a certain point, in one click would be nice.
Marc
2 Jun 2021   [#208] In reply to [#207]
Hi Marc,
Try this plugin.
SplitAtPoint.zip
3 Jun 2021   [#209] In reply to [#208]
Cool ! No need to select a curve!!!
French version :)
https://moiscript.weebly.com/pts-dune-courbe.html
3 Jun 2021   [#210]
Seems SplitAtPoint don't work with Circle, closed curves etc...
3 Jun 2021   [#211] In reply to [#208]
That's perfect .
And congrats on the new hockey team, lets see what those Krakens can do!
Marc
3 Jun 2021   [#212] In reply to [#210]
Yes that's correct, it can only split an open curve. To split a closed curve use the regular Edit > Trim command instead of this special version.
3 Jun 2021   [#213]
Or the "AddPt" command with the "Make corner point" setting, which puts an opposite point on a closed curve by itself, dividing the curve into two parts.
4 Jun 2021   [#214] In reply to [#213]
Hi, i would like to have groups of styles. I often come up with a lot of styles, and some objects with a lot of styles . Grouping should be convenient. The possibility of masking some styles inside the group, off course, and a way of quickly viewing only the group i want. Also some mechanism to select in a list when naming an object. I know there is a script to do that, but some kind of automatism should be easier.
25 Jun 2021   [#215]
I'd like to see a visual difference between a corner point and a smooth point. Both have very different attributes, but they look the same.
Maybe an option to set corner points to a square, or a different color, or some type of indication without opening a panel or running a script.
Examples:
Corner points in construction curves can cause unwanted behavior in Lofts and Fillets. I try to construct curves in the simplest way possible and only use corner points when needed. But they can appear when making a Mirror, and it would help a lot to see them at a glance.
Sometimes I want a corner point in the middle of a curve so a seam gets created. This allows me to assign two colors to the same curved object. Again, I can't just look at a curve and see the difference.
A bonus would be to have the ability to switch from one type to another by double-clicking on the point.
30 Jun 2021   [#216]
Function
Falling vertically an object to the next touching one...
5 Jul 2021   [#217]
I have a licensed program that only allows as many instances running on my network as I have licenses.
When I try to start another instance on another computer and I have no unused licenses it lists the computers running the program and asks if I would like to kill one and free up the license.
I would like to see that approach available with MOI - it would suit my working environment.
Frederick
5 Jul 2021   [#218]
Hello Michael,
I have got a question is it possible to create a closed circular object using patterns/curves distributed radially around a point/axis ?
5 Jul 2021   [#219] In reply to [#218]
Hi Psygorn, by "closed circular object" do you mean a sphere or a torus or something else?
6 Jul 2021   [#220] In reply to [#219]
Hi Michael I meant Torus!
Dear Michael please take a look at the attached file.
Also I have got another question for you! is it possible to rotate a desired curve along an axis while Array circular is used? I think with this we can create many interesting shapes :-) ! ( However I have to say I don't know if this type of effect is achievable by node-editor or not)
Edit: if you take a look at the attached file you will see a bunch of curves if you select them all and perform loft on them it MOI gives you an interesting shaped object! but unfortunately it is not closed! I wanted to know if there is a method to have the object just by using loft! ( I think it is possible to get the object by chopping some sections of it and then sawing those sections into the desired shape, I just wanted to know if it is possible by using loft command)
One more thing, I tried swipe and it gives me a closed object but there is a nasty twist at the end! How could I fix that?
Twist_Test_1.3dm
6 Jul 2021   [#221] In reply to [#220]
Hi Psygorn,
There isn't any option directly in the array circular command to perform an additional rotation on top of the one that it is already doing. But you could try using a combination of commands to get that effect, I'd probably try Array circular with the center point for the array at the center of the object with a vertical step applied. That will make a vertical stack of rotated objects and you can then arrange that onto a circle using Transform > Deform > Flow.
Another way you could do it is to make a vertical stack of unrotated copies and then apply the twist command on that.
There's a "Closed" checkbox option in the Loft command for doing that:
You'll need to drag the seam point for each section to control how they are matching up with each other. It might be easier for something like this to make a straight version of it and then use Flow to apply it onto a circle.
6 Jul 2021   [#222] In reply to [#220]
Hi Psygorn, so I think the twisting effect at the close point of the loft is caused from your rotation pattern not ending at a full 360 degree rotation at the end. I think your rotations add up to a final 180 degree rotation at the end so the end does not return to by synched up with the start.
I count 20 stations, and you have a rotation of 45 degrees for each station.
45 x 20 = 900 degrees.
900 degrees / 360 = 2.5
So the problem there is that it's spinning 2 and a half full rotations from the start to the end. The half part is what is the problem, you need the full rotation to be some even multiple of 360 degrees for it to make a non twisted result where the start and end meet up.
