Full Version: V5 Wish List
Show messages:  1-11  …  132-151  152-171  172-191  192-211  212-231  232-251  252-271  …  652-656
24 May 2021   [#192] In reply to [#191]
so many possibilities, Array files circular, vclone, Oriente Line/line (none) etc...
one method
orange tubes are stiches between Black & White faces
green tubes are stiches between white faces !
1 Black face top and 1 black face bottom
1 array circular from Top for 5 black faces, 1 array circular from bottom for 5 black faces
and only one circular for the last white faces with green tubes :)
26 May 2021   [#193] In reply to [#192]
Hi PILOU,
I did use array circular for creation of my soccer ball with stitches, but I would like to learn new (and possibly quicker methods) like vclone, Oriente Line/line (none) etc...
So, I'll check them and come back to you if i faced a problem.
28 May 2021   [#194]
Hello all, I would like to know your opinion.
Would it be a good idea to have such a thing in MOI?
Edit: I think this way users could save short keys and they could have access to a wider range of commands/scripts/plugins.
28 May 2021   [#195] In reply to [#194]
Hi Psygorn, I think that's probably something that I can set up as part of making multiple shortcut keys in sequence work in the future.
28 May 2021   [#196] In reply to [#195]
Tanx Michael.
29 May 2021   [#197]
Edit Frame behavior request:
Clicking on an Edit Frame handle toggles the round marker to let me know if I'm about to scale from the object's center, or from one side.
To get accurate mouse movements and see the object close up, I often zoom in to a level where the marker is off screen. I know I should look first to see what mode I'm in, but forget most the time.
Is it possible to add some kind of handle indicator, or handle color change, or handle line thickness change to show if I'm about to scale from the side rather than the center when zoomed in?
29 May 2021   [#198] In reply to [#197]
Hi Ed,
> when zoomed in?
Nothing really pops into mind for a color or thickness that would convey a meaning of "scale from center" vs "scale from corner".
Do you have any ideas on what that might look like?
29 May 2021   [#199] In reply to [#198]
Maybe if it's set to center....
29 May 2021   [#200]
The rotation tool of the Edit Frame is not very visible in numerous situations!
29 May 2021   [#201] In reply to [#199]
Dan & Michael - That's exactly what I was thinking. Just a little dot to indicated you're in Centered mode for those instances when you select an object, quickly zoom in, then think, "What mode am I in?"
29 May 2021   [#202] In reply to [#199]
Hi Dan, I'm not sure about that, the dot doesn't really indicate "centering" very much. Maybe though.
29 May 2021   [#203] In reply to [#202]
Something like this? But without the text.
29 May 2021   [#204] In reply to [#203]
A take on Ed's suggestion
MindSet
30 May 2021   [#205] In reply to [#203]
I've tried to let these sink in for a bit but they're still seeming kind of weird.
30 May 2021   [#206] In reply to [#205]
2 Jun 2021   [#207]
It would be nice to have 2d blend that would work on any part of the curve instead of just the endpoints.
An option to trim at that point would be interesting also.
Also, a function to directly cut a line at a certain point, in one click would be nice.
Marc
2 Jun 2021   [#208] In reply to [#207]
Hi Marc,
Try this plugin.
SplitAtPoint.zip
3 Jun 2021   [#209] In reply to [#208]
Cool ! No need to select a curve!!!
French version :)
https://moiscript.weebly.com/pts-dune-courbe.html
3 Jun 2021   [#210]
Seems SplitAtPoint don't work with Circle, closed curves etc...
3 Jun 2021   [#211] In reply to [#208]
That's perfect .
And congrats on the new hockey team, lets see what those Krakens can do!
Marc
