191-210
211-230
231-250
251-270
271-290
291-310
311-330
Bonus! ;)
Profiles are just Voronoi by Max Smirnov
Function Boolean Isect + native Hidden function "ExplodeMove"
(so just Press Tab then write ExplodeMove or make a ShortCut with the same name)
Of course if you want an "Inset" structure just make that!
The explode move gives a funny result but you must make another little trick for use this structure above!
The little trick... (of course the Cube B is closed! )
Take any volume smaller than A
Maybe there is another tip but this one works fine!
191-210
211-230
231-250
251-270
271-290
291-310
311-330
