108-127
128-147
148-167
168-187
188
Hi Michael.
Understood everything perfectly.
My pop-up window is only going to have little-used scripts, it is very overwhelming to remember 20-40 keyboard shortcuts, at least for me, that's why I needed this.
So once again thank you very much.
You can tell me where I can check the syntax of the version in which the MOI scripts are written.
For many years now, I was programming in C ++, Borland's version for MS-DOS (Windoss did not yet exist), and it would be useful for me to at least know how to modify some script, without going crazy.
If I need to add more sripts they will all be in a red box, to know that they are not tools.
Hi Booleano,
There isn't really a place currently where that can be checked other than by running it in MoI.
In the future i would like to work on a built in script editor that would help make it easier to write and debug scripts. It wiill take a lot of effort to make it though.
Hi Michael.
I really think that I would only need the necessary Java version, and I would search the Internet for the information I need.
I will never write a script, only on occasion would I modify an existing one.
Hi Booleano, the script language version that MoI uses is called JavaScript and the specific version name is called ECMAScript v5 .
Hi Michael.
Thank you
Don't understand what gives here:
MindSet
As you can edit Dimension Text anything can be writed!
or can be also an perspective effect!
etc...
So, it really doesn't offer measurements as fractions?
Hmm, maybe that makes sense; thought I was doing something wrong... both examples are coplanar.
Thanks!
Hi Mindset,
Dimension values are rounded using the setting under Formatting > "Decimal display" for decimals and Formatting > "Fractional display" for feet & inches.
So if you want to display a fraction less than that you'll need to set the display precision to be tighter. You can set the default used for new dims under Options > Dimensions, and you can set the properties for existing ones by selecting it and pushing "Details...".
If you're still having a problem can you please post the .3dm model file with your dim in it so I can take a look.
im loving it!!!! performance is great and so stable!
Ok, I finally got back to tuning up the web site a little more and there is now a "what's new" page for V4 here:
http://moi3d.com/4.0/whatsnew.htm
Super!
Hello Michael, everyone, I'd like to ask whether there are incremental updates to V4 since its initial non-beta release. The reason why I'm asking is because I upgraded to V4 pretty early on and I was wondering if there have been any minor version updates released since which I may be missing.
Thank you!
Hi Larry, no there haven't been any upgrades to v4 as of yet. I am hoping to start v5 betas soon, sorry it's taking a while to get that started.
Hello Michael!
Happy New Year to you and yours and everyone and everyone's here!
As far as I'm concerned, please take your time. You did exceptional work with both V3 and V4. I especially love V4! I only asked about minor version increments since I like to stay up to date with my software. V5 will be done when it's done.
Have an awesome 2022!
- Larry.
Thanks Larry, Happy New Year!
Hi there,
I can't get "Ext.Scripts" button to appear in my moi v4 GUI, I get it in the MOI v3 (but it's 32 bit so can't use it for bigger objects anymore) but whatever i do copy/paste scripts/ui stuff from v3 i to v4 i still can't get the button show up in moi v4 :(.
Can someone point me to example how to do that in moi v4 ?
Hi Lewis, the CustomUI mod from Max is different for v4. There is a new version of it for v4 and it is installed differently, in v4 it goes in the MoI appdata startup folder.
You can get it at
https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1 , use the link for the v4 one not the one for v3.
Thanks Michael, if i only could find it there in 485 pages.
Any hint on which page is located link for v4 :)?
Hi Lewis,
It's located on the first message of the thread, page 1 and it's the first link in the first message:
108-127
128-147
148-167
168-187
188
