 90-109
 110-129
 130-149
 150-169
 170-188
Hi Marco, also instead of calling the selection functions you could try calling:
moi.geometryDatabase.updateStaticFaceColors();
That should trigger the needed recalculation for changes to surface color. I will update changing surfaceColorMode to do that automatically.
HI. Thanks for help.
> was it that the edges looked ok but surfaces did not?
In can say for sure that surfaces were not updated but honestly I didn't notice If also edges has the same problem
Ok. I'll also try that.
Thanks Michael.
I'm now using the call to moi.geometryDatabase.updateStaticFaceColors(); to force a refresh of the surface color in the viewport.
It works :)
Please, help me also with this last (for the moment) question:
Is there a way to programmatically set the current Lighting mode?
I mean, a way to programmatically mimic what we can find into the moi.ini settings:
LightingOptions={"selected":"Porcelain"...and so on...}
I ask this because I need to store in a backup variable the current Lighting mode, then set it to a custom Light that I created, named "Drat 2", the reset it back to its original moi's setting.
Is there an Api call to set that LightingOptions={"selected"} ?
Hi:
I have this pop-up window, with several icons made by me, that call scrips.
They are what I know are within yellow lines
And I would like to know how to put a name under each icon.
This is a line of code for a custom icon in the "SidePane.htm" file.
| <moi: CommandButton icon = "moi: //ui/icons/ReconstructCurve.png" command = "ReconstructCurve"> </ moi: CommandButton>"
How would I have to modify each line of code.
Attached image of my window
Thanks. |
Hi Booleano,
>  How would I have to modify each line of code. Attached image of my window Thanks.
You would put the text content inside the opening/closing tag of the <moi:CommandButton> element, like this:
<moi:CommandButton icon = "..." command = "...">
Text content goes here</moi:CommandButton>
Hi Marco,
> It works :)
Great, that should work for now. That's a bug that I will fix up though, it should be doing that automatically when surfaceColorMode is modified.
Yes, check out the properties used in LightingOptions.htm .
Hi Michael.
Perfect.
Can the icons be resized?
If the text is long, it comes out like this.
Thank you.
Hi Booleano,
Yes, the icon size comes from this entry in moi.css :
moi\:CommandButton > img, moi\:CommandMenuButton > img, moi\:CommandSplitButton > img {
	width:3.25em;
	height:3.25em;
You can override that by putting in that same rule in a <style> block in the <head> of your .htm file, with different width and height values.
Message 10083.158 was deleted
Hi Michael.
DONE!
With this final tip I managed to modify an exixsting script that "render" the viewport into a file or into the clipboard.
Now, I'm able to generate two viewport renderings.
The first, that is the render of the current active viewport.
And the second, that is the "alpha channel" counterpart of the first render: the background if fully BLACK and all the objects are fully WHITE (using a particular lighting style)
In this way I can very very easily import both renderings into Affinity Photo and use the "alpha channel" render to cut-out the background of the rendered viewport.
Both renders are 8000x6000 or 12000x9000 pixels
Thanks for your help.
Hi Michael.
Once again, thank you very much for your invaluable help.
I have modified my custom window, only with the extra tools that are not in MOI.
But it would be great if you could include in this window, icons that run a script (Scrip1,Scrip2,Scrip3).
And it would look like the attached image (can I do any icon design instead of the "?" Signs).
What code should I use, and in what type of file to write it.
For example, how to put this script:
script: / * Create a style for each object name * / var AllObjects = moi.geometryDatabase.getObjects (); var NamedObjects = new Object (); for (var i = 0; i <AllObjects.length; ++ i) {var Obj = AllObjects.item (i); if (Obj.name! = '') {if (! NamedObjects [Obj.name]) {NamedObjects [Obj.name] = new Array (); } NamedObjects [Obj.name] .push (Obj); }} for (var Name in NamedObjects) {var style = moi.geometryDatabase.findStyle (Name, true); var Objects = NamedObjects [Name]; for (var i = 0; i <Objects.length; ++ i) {Objects [i] .styleIndex = style.index; var SubObjects = Objects [i] .getSubObjects (); for (var j = 0; j <SubObjects.length; ++ j) {SubObjects.item (j) .styleIndex = style.index; }}}
Hi Booleano,
Yes, you can make your own icon image saved as a .png file, copy the file over into the ui\icons folder,
and have them referenced as the other buttons do as an icon="" attribute on the command button tag.
For direct script code like that, you can put it contained inside of a function in a <script> tag inside the <head>
of your document, and have the script function called in an onclick="" handler on the command button tag.
So inside the <head> of your document, you would put:
<script>
function DoCreateStyles()
/* Create a style for each object name */ var AllObjects = moi.geometryDatabase.getObjects ();  ... rest of script code  here ....
And on your command button tag put:
<moi:CommandButton onclick="DoCreateStyles();">,,,
Hi
Thanks again for your help.
The ideal thing for me would be that you attach the documents for a script.
I don't know if there would be 2 files, for example the name would be "Styles"
1 - "Styles.htm"
And this
I don't know how it would be
I am attaching a file of what I think I understood.
Please, if it's wrong, you can modify it and resubmit it to serve as a template for the other scripts.
If the second file is missing, please can you send it to me.
Hi Booleano, if you attach the .htm file for your dialog instead of only a screenshot then I can make you a demonstration in your actual UI file.
Hi Michael.
If that's what I want, please, why don't I know how to do it.
I don't know Java and its syntax.
I thought that Google had translated it well, but it seems that it is not like that.
Sorry, and thank you very much again.
Hi Booleano, I'm sorry I don't understand.
Is it correct that you are working on a dialog box that has command buttons in it?
If so can you please post the .htm file for your dialog here?
Hi Michael
I apologize for not being able to express what I really need.
I attach 2 files that are:
"Script.txt" where the scripts that each icon in the attached image "Styles.jpg" and its corresponding code are indicated (it is written as it would be added as a keyboard shortcut).
"SidePane1.htm" is the current file of the pop-up window of the image "Styles.jpg", where the 3 icons of the file "Script.txt" are already added
I hope this time you understand what I want to do.
And the file "SidePane1.htm" that I need you to modify, I suppose it will help me to know how to add possible useful scripts for me.
And I thank you again for your invaluable help.
Hi Booleano, so for the icons you need to make each icon image into its own separate file. Usually the icons are 64 width 64 height PNG image files.
Then copy your 3 new icon image files into the "icons" sub-folder inside the ui folder. Then you'll be able to use them in a command button.
For running those scripts, step #1 is to modify your SidePane1.htm file to add a <head> section, usually <style> and <script> go in the <head> section of an html file.
So that would look like this:
<html>
	<head>
		<style>
			/* Turn off text block under command button icon */
			moi\:CommandButton > div {
				display:none;
			/* Cambio de tamaño de los iconos */
			width:8em;
			height:8em;
		</style>
	</head>
	<body class="SidePaneBody">
Now add a <script> section inside the <head> after the <style>:
<html>
	<head>
		<style>
				display:none;
			width:8em;
			height:8em;
		</style>
		<script>
		</script>
	</head>
Then inside the <script></script> section you can add  functions that contain script code:
		<script>
			function ScriptCodeFunction1()
		</script>
copy the script code from your Scripts.txt inside the function, in between { }.
To make a command button call the script function, put in an onclick="" attribute in the moi:CommandButton element, like this:
<moi:CommandButton icon="icons/icon_filename.png" onclick="ScriptCodeFunction1()">Text here</moi:CommandButton>
You can remove the command="" attribute from these particular 3 buttons, they will be calling script code inside this same file instead of running a command.
Let me know if you're still stuck.
Hi Michael.
Understood everything perfectly.
My pop-up window is only going to have little-used scripts, it is very overwhelming to remember 20-40 keyboard shortcuts, at least for me, that's why I needed this.
So once again thank you very much.
You can tell me where I can check the syntax of the version in which the MOI scripts are written.
For many years now, I was programming in C ++, Borland's version for MS-DOS (Windoss did not yet exist), and it would be useful for me to at least know how to modify some script, without going crazy.
If I need to add more sripts they will all be in a red box, to know that they are not tools.
Hi Booleano,
There isn't really a place currently where that can be checked other than by running it in MoI.
In the future i would like to work on a built in script editor that would help make it easier to write and debug scripts. It wiill take a lot of effort to make it though.
 90-109
 110-129
 130-149
 150-169
 170-188
