19-38
39-45
Hi Teddy,
> I wonder if the location where MOI 3.0 stores files like these is different than later versions? I created this using v4.0.
Yes version 3 didn't support having commands in appdata, that was new for MoI v4.
Thanks Michael. I couldn't remember when changes occurred, but that makes sense. I did use v4 while in beta, but I hadn't upgraded due to the fact I haven't been using the program much. Just today, however, I came across a new reason to use MoI but I am not sure I really need the view manager for what I am doing, I just thought I might.
I will give MoI a tip of the hat in my next Design Talk when it comes out as it has made my day with it's .eps import function from a 2D vector drawing program called Affinity Designer that doesn't have dxf or dwg export functions, which I would have typically used when I used Adobe Illustrator.
You know, every time I use MoI I am simply amazed at its capabilities and it ease of use. Keep up the great work! I should really just go ahead and update, even if it is only to show my support.
EDIT: I upgraded to v4. View Manager now works as expected. Thanks.
Hi Don, thanks very much for the upgrade and the kind words! :)
You can also use the PDF format with Moi <--> Affinity Designer! ;)
I finished my new design talk. In it I give mention to MoI. If you don't feel like watching the whole video, I start the process of introducing Moi on slide 17, show it in 18 and wrap it up on 19.
Link to free-to-watch video:
https://youtu.be/FCsm8UZktus
Thanks very much Don!
Hi Don,
Very Interesting,
Thank you
19-38
39-45
