Full Version: V4 beta Oct-27-2020 available now
Show messages:  1-8  …  29-48  49-68  69-88  89-108  109-128  129-148  149-158
1 Nov 2020   [#89] In reply to [#87]
Hi Larry, I'm glad the arrow gap setting is useful!
Re: MiterArrowheads=n , (http://moi3d.com/forum/index.php?webtag=MOI&msg=9363.86)
The MiterArrowheads moi.ini setting only has an impact on the viewport display inside of MoI, it doesn't affect PDF/AI file content.
Closed arrowheads in the PDF/AI content are not mitered because they have only a fill set for rendering their paths, not a fill + stroke. So for closed arrowheads, there isn't any piece of it that extends further than the tip point.
It's difficult to make the same thing happen on screen vs in PDF file because the screen has a far more limited resolution to work with.
1 Nov 2020   [#90] In reply to [#78]
Hi nameless,
re: moi.ui.getLastOrientationPickerFrame()
So yes this piece should now allow a script to be created that does an "ImportPart" (right click on File > Import) or "PastePart" function (Ctrl+Shift+V) which positions the inserted objects to also scale the object by the proper origin point as an additional step.
I've attached a try at making those here, these versions "ImportPartWithScale", and "PastePartWithScale" should include a scaling step after the positioning. Hope that is close to what you were thinking of.
ImportPartWithScale.zip
PastePartWithScale.zip
1 Nov 2020   [#91] In reply to [#90]
Michael,
This is stellar... I can't believe you made this happen so quickly. For me, asset placement is solved with the most elegant/intuitive way.
Thank you so much for keeping your eyes on MoI user needs and for helping us tirelessly. It's so inspiring!!!
1 Nov 2020   [#92] In reply to [#91]
Hi nameless, you're welcome! Through e-mail you asked if this could be used in the CustomUI object library. I think that should work ok, you would edit the file ObjLibrary.menu.htm on line #26:
			else { moi.command.execCommand( 'importpart '+file); }
Make that say importpartwithscale instead, but take care not to accidentally remove the space that is after it.
1 Nov 2020   [#93] In reply to [#92]
Perfection!
2 Nov 2020   [#94] In reply to [#72]
thanks for more details regarding "4views" project.
>So I mean more like this - you have your model you've made in one file, and a title block template set up in a separate file. Now go ahead and add in dimensions on your model. Then you export to PDF and there is an option for the view configuration. It would have options for "Top", "Front", "Right", "3D" (all single view drawings as it is now), "4 views", or "Use title block template".
If I understand it correctly I make dimensioning on model (part) in all required views in one file, let say in MOI Split view, which is similar to 4 view projection. That's fine.
Only two questions:
.: Would it be possible to "turn off" unusable/invisible dimensions in given view and in 3D view? I mean dimensions marked by white arrow.
.: Would it be possible to specify before export First-angle projection or Third-angle projection (https://en.wikipedia.org/wiki/Multiview_projection)? I mean for example Top, Front, Right and 3D view in specific order given by ANSI or ISO standards, pls see bellow.
Thanks a lot.
Mik
2 Nov 2020   [#95] In reply to [#90]
BTW:
ImportPartWithScale is very useful script, only as a reminder for me, that Import Icon has two different options, I've reworked ImportIcon.png and copied to c:\Program Files\MoI 4.0 beta Oct-27-2020\ui\icons\ImportIcon.png
Mik
2 Nov 2020   [#96] In reply to [#95]
Mik, I wasn't even aware of the existence of this RMB mode of import button until I read your comment!
2 Nov 2020   [#97] In reply to [#96]
I don't either :-D
MOI is so intuitive that it isn't necessary to read Command Reference :-)
Mik
2 Nov 2020   [#98] In reply to [#94]
Hi Mik,
Yes, that's the idea.
Yes, to make this work there would need to be a new property on dimensions. Something like:
Show in: "All views" , "Ortho views only" , "3D view only".
Yes, the idea is that you would be able to put any arrangement you want in the template file. In the template file you would put a rectangle where you want to have a view placed and give the rectangle an object name to identify the view to use. I was thinking the 3D view would use the view from the current 3D viewport but maybe there could also be a way to specify a particular view direction in the template object name as well.
2 Nov 2020   [#99] In reply to [#98]
3xYes in answers... that sounds promising :-)
Seriously, it would be absolutelly perfect!
Thank you.
Mik
10 Nov 2020   [#100] In reply to [#98]
Will the "Ortho views only" hide, for example, the "Front" dimensions to appear as lines in the "Top" view ?
I mean just like the "thickness" of "Images" placed in the "Front" view are invisible in "Top view".
Would there be a "View" property of a Dimension that makes it belong to a view ?
Actually, I find Make2D Script quite useful because it makes it very easy to add measurements to the Ortho views.
Would it be interesting to have that script included in the dimensions Pane ?
The only thing I would like to be added to it would be to act like placing an Image
(I mean letting the user choose (click) where the 2D should appear in the 3D space).
Thanks for the hard work !
Looking forward to the final v4 version.
Michel
10 Nov 2020   [#101]
Here are some observations on v4 beta:
Copy as PDF :
When "Exporting as PDF", the objects sizes are preserved while when "Copying as PDF" they aren't.
edited :
(could be a problem with the way Affinity Photo and Affinity Designer read the PDF.
If I "Place" a previously exported PDF file into the Designer document and double
click it, it opens an "integrated window" and if I then "Paste" a copy PDF from MoI in it, the size is ok).
Copy and Export as PDF
Tick marks have the thickness of drawing lines instead of being the size of dimension lines.
Small display error when drawing solids (not specific to v4. It is really minor as the result is not affected) :
Draw a solid cube, lets say 10 x 10 x 10, starting at Origin, then, in the 3D view, start drawing another solid (or a rectangle) right "underneath" the first one, again starting at Origin. When you move the mouse to the back of the plane, it will display a negative value as long as the cursor is moved under the measurement of the bottom of the solid on top.
It doesn't cause any error if you click to fix the point. It is just indicating a minus sign in a positive area while moving the cursor.
Dimensions wish :
Would it be possible to add the Style (color) property to the Defaults as it already appears in Details?
Extrude command wish :
Not exiting the command after specifying extrusion length (would wait for right click by user).
It is similar to an earlier demand by Leonardo, but more specific to the use of options within the command.
Specially if Tapered is activated, if one enters the Extrusion Distance then press Tab, the cursor won't go to the Draft Angle text box.
If Tab is pressed, it would be possible to go back and forth Extrusion/Draft angle and only end the command on right click.
Add an Axis Show/Hide check box in the "Grid Snap" button wish :
This check box would be under the Show Grid checkbox.
Thanks again,
Michel
10 Nov 2020   [#102] In reply to [#100]
Hi Michel,
I was thinking "Ortho views only" would have the same behavior as current ortho views. But there could be additional settings to limit it to just one ortho view. Maybe:
Show in: "All views", "Ortho views only", "3D view only", "Top view only", "Front view only", "Right view only".
Yes this would be a setting for a dimension to be displayed only in certain views so you could control generating a multi-view PDF file better.
Yes that seems like it would be good.
They are selected when the command ends so you can position them using Transform > Move or dragging them. Maybe there could be an option to generate it inside a rectangle with a specific object name similar to how a title block template could work.
11 Nov 2020   [#103] In reply to [#101]
Hi Michel, thanks for the feedback.
> Copy as PDF :
> edited :
I'm not able to repeat this with Adobe Illustrator, it appears to be a quirk in how Affinity handles pasting. It appears to be sensitive to the DPI setting in Affinity. Affinity seems to think the PDF file is 72 dpi (I don't think there is actually any kind of dpi setting for a whole page in PDF), and if your current Affinity document has a different dpi then it scales it.
Before you paste into Affinity, if you go to Document Setup > Dimensions and set DPI = 72 then it seems that it will paste it over without altering the size.
Pasting into a "Placed" PDF file works I think because the placed PDF file has DPI = 72.
Tick marks have their own line thickness setting which is used. It's set in the Annotation properties > "Arrows" section, "Tick line width".
You can alter it for an individual object using Details... or set the default for a newly created one under Options > Dimensions.
> (width shows as negative)
It's actually not an error - it's due to the drawing using the faces of the cube as the current snap plane when you are placing points in the 3D view and have snapped points onto an object. If you turn off object snap or hold down Alt to temporarily turn off object snap for that pick so you don't have both points snapped onto the plane then it won't use the solid cube's plane as the current cplane orientation.
This is what allows for drawing things like rectangles directly onto the face of a box when you are picking points in the 3D view.
> Dimensions wish :
Hmmm, well currently when you draw any object it gets the "active style" applied to it, that is the one that has a ring around its color swatch in the Styles list in the Scene browser. You can set it by right clicking on a swatch. That is how the style assignment for new objects works for all object types including dimensions. But if I understand you correctly you want a way to set a default style for a dimension in the dimension preset instead of having it use the active style?
I don't know, this may be too big of a change. Having an extra step for all uses of Extrude is kind of like paying a "workflow tax" on all simple extrusions just to make that back and forth between Draft angle and distance work for the tapered case.
If you want to put this in now, you can do it by editing the file GridSnapMenu.htm inside the ui folder.
Add this below the <moi:CheckButton> for "Show Grid" on line #19 :
		<moi:CheckButton binding="value = moi.grid.showXYAxes"><moi:Text textid="Show grid axes checkbox"/></moi:CheckButton>
11 Nov 2020   [#104]
Hi Michael
Thanks for all these improvements
i m using Dim without changing "aux" plans
the next file is a animed gif
do you think that i use it like i should ?
Chri
11 Nov 2020   [#105] In reply to [#104]
Seems you don't use as you should! ;)
an hypothenuse diagonal is bigger than a side...etc
else the rest is tricky! ;)
Inclined vertical or horizontal selection is cool : only one point to move after for have same length of dimension!
11 Nov 2020   [#106]
In 3D View seems the rule is not to click on vertex but on edges for better position dimensions wanted !
and move points after if needing!
11 Nov 2020   [#107] In reply to [#104]
Hi Chri,
I guess so - is there a particular result that you are not able to get?
One thing to note is that when you are drawing in the 3D view, the view direction plays a role in what plane will get used. It will be the one that is closest to facing you.
Here's an example - here I'm doing the same Dim Horizontal drawing command on the same points, but adjusting the view between uses to target different planes:
11 Nov 2020   [#108] In reply to [#107]
"Plane" is depending of the rotation of the 3D view ?
Trick of the inclined selection avoid to rotate the view but there is no equal length of side lines...
I suppose that is not visible if lines are same color than volume for print ?
Indeed (but i have not Printed for see if "artefact" are visible or not!
