79-98
99-118
119-138
139-158
Hi Ad,
> And attached are the screen shots as requested. As you can see on the "General Tab" as well as
> all other Tabs the text color on the Drop Down Selections is amber or orange, however you want
> to call the color. I the "Dimension Tab" the text color is black. All direct text entry fields the text
> color is a light gray, but this is ok.
Can you post the moi.css file that you're using?
The difference between the "General Tab" dropdowns and the "Dimension Tab" dropdowns are that the ones on General are <moi:Select> controls while the ones on the dimension tab are plain <select> elements since they didn't need to use the binding mechanism that is only present on a <moi:Select> control.
So probably the solution will be to adjust the rule in moi.css that is setting the color for <moi:Select> controls to also apply to plain <select> controls as well.
> One thing I forgot to ask in my last post: Is there a way to change the text orientation for vertical
> dimensions to horizontal? I think it works for "Scaling by screen Units". I attached a screen shot for this as well.
Yes, the text can be set to horizontal by the "Display" property, set it to Display: Screen Aligned. You can do this to an individual object by using the "Details..." dialog, or make it the default for newly created ones under Options > Dimensions.
Attached is the moi.css file. I renamed it to "moi-modo.css" only for the purpose to upload it. The file I use is still just "moi.css". I was also wondering where the highlight color settings are for active input fields, see attached screenshot. With the current color settings it is hard to see where the focus is.
Thanks for taking the time to help me out on that.
Ad
moi-modo.css
Hi Ad, so for the drop-downs, the problem is that the regular <select> control has a default color built in to the base WebKit html.css .
So to fix that, inside moi.css find the base rule for <moi:Select> and <select> controls which looks like this:
moi\:Select, select {
-webkit-appearance:none;
-webkit-box-sizing:border-box;
-webkit-box-align:center;
white-space:pre;
background-color:#2F2F2F;
margin:0;
display:inline-block;
border:1px solid #686868;
border-radius:2px;
font-size:90%;
and put in a color:inherit; in it so it looks like this (added at the end):
white-space:pre;
margin:0;
border-radius:2px;
font-size:90%;
color:inherit;
So one of the things that's a little bit off with this moi.css file is that it's based off of the .css for MoI version 3 so some of the things like the flex-box properties are not matched up right for v4 which is why a few things look weird. I'll see if I can tune it up.
For selected text, add in this which is also in the v4 moi.css file now:
/* Background and text colors for selected text in input fields */
::selection {
background-color:#5599FF;
color:white;
Hi Ad, here is the moi-modo.css that has the flex-box properties set up for v4, that should fix things like dropdowns having space to the right of the down arrow button.
moi.css
Thanks a lot for your support. I will try this shortly, but I'm sure it'll work just perfect.
Edited:
As expected, perfect :).
One more question in regards of color settings. I would like to change the highlight color for adding new Keybord Shortcut Keys (see screenshot). After I took the screenshot, I sampled the color and did a search for that RGB as well as HEX value in the moi.css file, but it was not there. So I asume this is another case where I need an "inherit" statement? Which section in the css would I have to modify?
Thanks again, and I'll promise I hold myself back now with more questions :).
Ad
Hi Ad,
That one is set up in a local style sheet in ShortcutKeysOptions.htm :
/* Color of selected row */
.SelectedRow {
background-color:#EBEBFF;
So you can modify it there, or if you want to have it in moi.css it will need an !important so it overrides the one in the local style sheet.
Thanks for the info. Haven't run across a locale css file, but I didn't dig around in the folders too much. I will try to locate it, otherwise I just add it to the moi.css. Yeah, I've seen the !important statements, now they make more sense. I'll give it a shot.
Ad
Hi Ad, the local css part is not a separate .css file, it's embedded in a <style> element at the top of the .htm file.
So for example that one is in a <style> element at the top of the ShortcutKeysOptions.htm file.
Question about editable points - if they will be added to script environment ? v4/v5 ?
Hi Tudor,
That's not going to make it in for v4 but I can put it in for v5 once the v5 beta process starts up.
I already added the color option to the moi.css file, works fine. But thank you for pointing me in the right direction with the local css. Much appreciated.
Ad
Here's a little regression, nothing very important, in the meshing option when exporting a file.
Emptying field like 'divide larger than' doesn't disable/reset the option anymore, you need to enter 0 to overwrite previous value and disable the feature.
I don't know if it's an intended behavior.
Sorry if it has already be reported.
Cheers.
Hi PaQ, thanks I can repeat the regression over here. It seems that the previous behavior of emptying a field generating a 0 result automatically was kind of a side effect from something else but I should be able to restore the behavior purposely now.
Thanks for reporting it!
Arg I'm right now so frustrated. I opened Moi beta after a few months of not using it. It told me the beta version I had was outdated. I downloaded this one, everything went well and my shortcuts were working without issues when I opened it for the first time, but today I opened the program again and my ini file was overwritten with defaults and I lost all my shortcuts. Ahhh crap this sucks... I had so many things, took me forever to put together these shortcuts. Has anyone else experienced this?
Hi rolnxyz, I have not heard of any issues previously with the shortcuts spontaneously resetting.
Are you running on Windows? Try going to %appdata%\Moi and right-click on the moi.ini file there and choose "Properties". On there check the "Previous Versions" tab to see if there are any older versions saved from a previous Windows restore point backup.
That moi.ini file is where all that is saved, and that's also the file that would be good to save off to a backup if you have done a lot of customization.
Message 10011.154 was deleted
I tried restore yesterday, and realized I don't have the backups enabled. I just enabled them. I thought it would take me forever to get all of them back, I've been working and searching in the forums every time I missed a shortcut, and I got, at least the important ones that I used all the time.
If I reproduce the issue again I'll let you know. The only thing I remember changing yesterday was the unit from being unitless to use inches in preferences. I had the shortcuts in %appdata%/Moi on windows 10.
Also, this is one of my favorite 3d programs, best ux. Thanks for all the hard work.
Maybe you have also pressed button "Restore Default" against "Close" (for validate) in Options / Shortcuts ?
@ Michael : maybe will be a good thing to place the alone button "Restore Default" on the left bottom opposite corner ?3 times!
for avoid this ! :) I have made it alas 2 or 3 times!
Hi Pilou, that's not a bad idea but pushing "Restore Defaults" pops up a dialog box and asks for confirmation, it doesn't do it immediately with just the one button press.
Double security! ;)
79-98
99-118
119-138
139-158
