Full Version: AutoRotate script final
Show messages:  1-10  11-30  31-35
25 Aug 2025   [#31] In reply to [#29]
Hi Zooen, I'm glad you got it working! I've attached the file with the edit in it that I was trying to describe.
AutoRotate2.js
25 Aug 2025   [#32]
My 2 cents.
If you want something like autoRotate to have a simple render, look at Koru software.
MoI is wonderfull and perhaps the best CAD for artistic model but it's not a render tool.
I think if you want an easy and good render with a rotation effect, Koru is a very good choice.
It can export your work in a html page with Webgl and easy add a script to rotate the camera.
If you let it work, the webpage will rotate the cam.
If you use your mouse to rotate and stop touch it, after seconds, it will re-rotate the cam.
And as a webpage, you can open it with any device, Computer, smartphone, tablet...
A quick sample here... Click_it
26 Aug 2025   [#33] In reply to [#32]
Hi Phiro,
Merci pour l'information.
Thanks for the information, I'll look into it. Well, it's not free.
I use ShareX 18.0.1.
ShareX is a free, open-source screen capture and screencast program for recording everything that happens on screen.
26 Aug 2025   [#34] In reply to [#31]
Thanks Michael,
Even though my tweaked AutoRotate2.js works, I've gone back to yours, certainly more in line with the code writing!
26 Aug 2025   [#35]
Koru shown example has not a complete rotation! ;)
Spline 3D yes! ;) Don't use it for a while! :(
https://moiscript.weebly.com/spline.html
