Newby editing a solid question
9992.2 In reply to 9992.1
I'm fairly new myself so I don't know all the solutions to this kind of problem.
What I have been doing is using one of the front/top/side views and drawing a line across the object where I want to split it into two pieces.
Then apply "boolean diff", using the line as the object to remove, and you have two pieces.
At that point you can re-create the part that is wrong or add to the existing part.
Then you use "boolean union" to put it all back together.
Frederick
