Newby editing a solid question
9992.14 In reply to 9992.13
Yep i use only SimLab (because it's very easy and permit to mix many 3D formats in the same time ) in free that is now 1920*800
or even SketchUp format! So no problem of regulate : you can play with smaller etc... if you have complex volume...
example with a model by thegoodguy
I have not made any special regulates (that was just for a test :)
Here SketchUp export from Moi : as you see you are not obliged to use OBJ format :)
A trick : export different objects against all in one if there are several complex objects!
You have another very cool free one (if you had loaded it previous year) : TwinMotion ! Without any limitation!
Updates are free too!
EDITED: 29 Oct 2020 by PILOU
