Question about NodeEditor "Switch" Node
9984.21 In reply to 9984.20
The two new switch nodes should be copied to the %AppDate% > nodeeditor > nodes > extensions directory.
The switch nodes then get loaded by the nodeeditor program, to the Widget menu.
Existing Widgets of Max are not changed. Max's Interface.js file is not changed.
These nodes are separate files, but are based upon Max's code, with some modifications made.
After much study, the "arcane" to me code starts to make a little sense, but is still not totally understood.
The two files could be sequentially listed in a combined file, in the future.
EDITED: 20 Oct 2020 by BEMFARMER
