PDF export in V4
9983.1
I am having some issue with the PDF export. I need to export a drawing to scale and so I selected the preserve units option. The drawing is exported to scale but the objects are somehow misplaced.
If I do not select "center on page" the origin in the model correspond with the 0,0 in the drawing sheet, so the object is placed next to the bottom-left corner. If I do select "center on page" the objects are placed in the top right corner and mostly out of the paper rather than at the centre of the sheet.
Would it be possible to set somehow a margin on the left side and at the bottom of the page (10mm or plus) in the PDF sheet so that I can control the distance from the origin without moving the drawing around?
Salvatore
