Usage of SubD Create from file
9970.3 In reply to 9970.1
Hi Andre, yes that is the expected outcome for that function, and that is correct that it is not intended to be used for STL conversion.
It's not a general purpose importer that can work on any kind of polygon structure, it is meant to be used on a polygon mesh that has been constructed as a control cage for subdivision surface modeling.
A sub-d control cage should be a lighter weight polygon structure that primarily uses quads, not a set of dense triangle polygons like you have in your model.
There's an overview of sub-d modeling here:
https://www.youtube.com/watch?v=ckOTl2GcS-E&t=4s
This function is meant to process the kind of quad-dominant polygon structures that you can see in the video. It is able to convert those control cages into smooth NURBS surfaces so you can use them as parts of a model that you are constructing in MoI.
It's basically a bridge between sub-d modeling and CAD. But it is specifically for sub-d models, not triangle mesh models. That's why it is positioned in the UI in a SubD tab and not in the general File > Open.
EDITED: 3 Oct 2020 by MICHAEL GIBSON
