eps, pdf
997.2 In reply to 997.1
Hi Gyuri,
> Is, it possible to convert bmb into eps, or Pdf, then import to Moi as an editable curve?
It is possible, but the complication is that both eps and PDF can also contain bitmaps inside of them as well as curve vector information.
Probably the conversions you are doing are resulting in embedded bitmaps inside the eps or PDF files.
You need a more specialized "vectorizer" program that will actually try to trace the outlines of your bitmap with curve objects, rather than just translating the bitmap over. I'm not really too familiar with these programs myself, but I think there are several different ones available, maybe someone else has some experience with some of them.
Also .eps files can sometimes more difficult for MoI to read, so you should try to convert to .ai or .pdf instead if that is possible.
