Edges & Visuals
9958.14 In reply to 9958.13
Hi Stefano,
> the issue i am finding is I will be selecting other objects usually on drag selecting. Then its another de-selection.
You can solve this by hiding the other objects so only the one you need to work with currently is visible.
A quick way to do that is to select your object of interest and then right-click on the Edit > Hide button. That will trigger the "Isolate" function which will hide other objects and only leave the selected one showing. When you're done right-click on Edit > Hide again and things will return to the same visibility state as before the isolate.
> I'd be interested to know if all the colours I am showing as 'EDGE selection groups' in this video
> could actually be 'identified' by a script. Ideally, few click solution.
So you mean the vertical lines but only the ones on the outermost surfaces? Right now I can't really see an easy way to identify those using script.
I would recommend using 2 window selections like you show.
