Edges & Visuals
9958.1
Few questions about edges...
1. Is it possible to selectively highlight/select an edge element and remove/hide it so when you show 'edges'
in the types list it does not show up (for example vertical line on the internal radius - hide)?
>>Noticed i can select the vertical part but there is no 'transparent colour' in styles.
Potential solution: Put these objects on "HIDE" Layer(Style) or script ??
2. Is it possible to change the colour of the edges to be a bit more subtle on some objects?
>> Likely I would use a custom STYLE for this.
3. Is it possible to make one object have no edges displayed so even if the type has EDGES "ON"
a few objects ignor the global setting?
>> As per #1?
EDITED: 19 Sep 2020 by LIGHTWAVE
Size: 13 KB, Downloaded: 59 times, Dimensions: 929x606px
Size: 18.6 KB, Downloaded: 30 times, Dimensions: 709x253px
