Unable to center when exporting to PDF ?
9955.3 In reply to 9955.1
Hi Sven, there is a bug with centering with "Preseve units" in this release, it centers on the top,right corner instead of in the middle of the page.
You can work around it to get workable output by turning off centering and instead make sure that your objects are inside the page coordinates. So for example if your units are inches you would need to make sure your objects are located inside a rectangle of 0,0 to 8.5,11 (for 8.5x11 inch page size). Then it should be visible in the output page.
If you can send me an e-mail at moi@moi3d.com, I can send you a test version with a fix.
