Michael,
I love V4 so much! MoI just keeps getting better and better.
A couple of questions:
Is there a way to get the sidebar items to move all the way at the top of the column? I don't have the largest screen, and when MoI boots, it seems to try to stack the default configuration of menus in the middle of the column. Problem is, when I open more or larger menus, I end up crowding against the bottom of the screen, but there is wasted empty space at the top.
Perhaps there is some necessity for this arrangement of which I am unaware. If not, is there a way to start out with the menus all the way to the top, so that I can use the full column?
Also, I noted the discussion where you provided a script to get all of the sidebar menus separated, so they can all be accessible at once, if need be. My need is more modest. I only want to split the Construct and Transform menus. These are the only two that I find myself constantly switching between while working. The other groupings work fine, as I seldom need to access features between them in the same session. Further searching in the forum turned up a way to do this by editing the file "SidePane.htm." Oddly, when I tried this with V4, the file seems to be empty when opened in (Mac) TextEdit. There's something there, but it doesn't seem to be text. I appears like a bunch of empty table cells. What am I doing wrong? The other .htm files load up the same way...
Mark
